How to Make LED React to Music
About: I am a 14 year old boy interested in every single thing related to computer...... I love Robotics.....
Heres a list of parts you will require to make it -
  • Normal LED Strips - RGB Will Also do the work
  • A Speaker System
  • Solder Iron
  • Wires
Teacher Notes
Step 1: Step 2 - Soldering the Wires (Normal LED Strips)
Just Solder the negative and the positive terminal to the LED strips terminal
Step 2: Step 2* - Soldering the Wires (RGB LED Strips)
For the RGB LED Strips, you can solder particular color ports to obtain the color you want. Above this, you can see the color chart to make out which you gotta mix to get the color you want
P.S.- I'd be uploading a color changing LED Strip Reacting Video
Step 3: Step 3 - Hooking Up to Your Sound System
For Normal LEDs
Take your positive terminal wire and push it in the +ve terminal of the speaker output and the negative terminal into the -ve terminal of the speaker output
For RGB LEDs
Do the same as above but just push the R, G or B wire into the -ve terminal. push two of them together to make a new color!
Step 4: THE MOST IMPORTANT STEP - Enjoy! :P
Go and now boost up your sound systems and enjoy your life! Here are some beat drops which I think you'd Love to play on it - Here is a playlist I made! Have fun!
Make it Glow Contest 2018
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
