Stitched Leather Coaster
Introduction: Stitched Leather Coaster
I was racking my brain as to what I could realistically make in one hour and then one day I was having a drink and needed a coaster so I grabbed a piece of scrap leather. You can guess the rest.
Supplies:
  • Leather (Horween)
  • Leather Marking Pen
  • Knife
  • Metal Straight Edge
  • Lighter
  • Edge Beveler
  • Leather Glue (Seiwa water based glue)
  • Wing Divider
  • Pricking Iron (3.85 mm)
  • Waxed Thread (0.6 tiger thread)
  • Stitching Needles
  • Sandpaper
Step 1: Cut Your Pieces
  • Figure out how big you want your coaster
  • Cut 2 pieces of leather with one slighter larger than the other.(I do this because I would prefer to trim off excess, rather than line up the edges perfectly )
Step 2: Glue and Trim
  • Apply glue to the smaller piece
  • Make sure to have good coverage along the edge of the piece, you don't want your coaster to spit or fray down the line
  • After glue has dried, trim off the excess
Step 3: Round Corners
  • I think round corners give the coaster a much more finished look so
  • Get something to help you draw a round corner, a quarter till do just fine
  • And cut on the line you drew
    • Rather than making one big curved cut I make small straight cuts taking off a little bit at a time, sort of like cutting your nails
Step 4: Sand Your Edges
  • Give your edges a quick sand to smooth out the edges
Step 5: Bevel Edges
  • Use an edge beveler to bevel your edges
  • I also used sand paper to bevel areas that were harder to bevel such as the rounded corners
Step 6: Mark Stitching Line
  • Using a wing divider mark your stitching line
  • I set my wing divider to 3mm
Step 7: Punch Your Stitching Holes
  • Following the stitching line you just marked, punch out your stitching holes
    • Making sure your prickling iron is perpendicular will ensure that the holes are aligned on the back side
Step 8: Stitch
  • Stitch your piece together
    • If you have a stitching pony, it will make this process alot quicker
  • When you made to the end, cut your thread and singe
Step 9: Done
  • You can do any sort of touch up you like but essentially you are done!
1 Hour Challenge
1 Hour Challenge
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
