Stranger Things Shadow Box Build
Introduction: Stranger Things Shadow Box Build
About: Project Manager by day, Maker by Night. Based out of Milwaukee, Wisconsin. I make things based on the Geeky things I like.
Using a Glowforge laser cutter I made a layered, resin filled Stranger Things Shadow Box from a drawing originally created by alcateiaart out of Sao Paulo, Brazil.
I used my iPad to trace out the designs I wanted, took the layers into the computer to create the laser cutting files then went to building. I used Promarine Resin (link on our website) to fill each layer. I hit a major snag when I applied WAY too much super glue to finish the piece. After a lot of careful sanding the shadow box was complete and looks great on our shelf.
Glowforge Referral Link: https://glowforge.com/?gfs=referral_p...
For the cut files, head over to https://whengeekscraft.com/build-files/ Links to tools used in this build: https://whengeekscraft.com/shop-tools/ FOLLOW: https://www.instagram.com/whengeekscr... https://www.facebook.com/whengeekscraft
Supplies:
Head over to www.whengeekscraft.com for all the build files as well as the tools used!
Step 1: YouTube Build Video
Here is the entire build process! Please comment what you think and subscribe for more! This was our first build video. We plan on using a better quality camera on some of the wide shots but are very happy with the top down shots
Step 2: Create the Design
  1. I started by working off of an inspiration piece. I saw a silhouette photo that really drew me in and decided to start from there. I decided to find a different Image to use for the Kids on the acrylic layer because I wanted them to be running rather than standing still.
  2. After I traced out all my layers on Sketchbook with my apple pencil I exported all the files as Photoshop documents. In Photoshop (or gimp) I cleaned up the layers then copied and pasted them into Inkscape. I found the Stranger Things Logo and made it into a Bitmap image. Sent it all to the laser and started building!
Step 3: Laser Cut the Files and Start Pouring Resin
The build files are available on my website www.whengeekscraft.com
  1. I laser cut each layer out using my Glowforge out of 1/4 inch red oak plywood. This is stainable plywood that laser cuts very well! I made three layers of trees as well as a frame for them to be glued into.
  2. After cleaning with some orange pumice soap to remove burn marks, I stained each layer of wood then started assembling the box. I painted the back panel white to help the color for the resin shine brighter.
  3. As I glued in each layer of wood, I poured enough resin to fill that area. I started with darker pigments and went lighter with each layer to add depth. Each resin layer sat for 8 hours before the next layer was to be glued in place. The final layer was a clear coat to help joint the two sections of color consistently to the correct level.
  4. I painted the Acrylic sheet that was going to be the top layer. I kept the masking tape on because it allowed the paint to go just in the engraved sections. After the paint was dried From the Kids and the Logo, I removed the masking tape.
  5. I ran into a MAJOR mistake when I tried to finish the box using super glue. I put way too much causing it to pool and with no access to air under the acrylic, it moved under the top layer like water. I decided to take it all apart. when we did, the super glue INSTANTLY dried. I remade the top acrylic piece, went through the process of sanding the resin layers and then rebuilt the frame.
  6. I sanded the resin but going through the following sanding grits: 120, 280, 400, 600, 1000,1500, Polishing abrasive, polishing cleaning. What's a project without a disaster!! Heres link to me going through ALLLLL that sanding https://www.instagram.com/p/BxxCnJnjiSD/?utm_sourc...
  7. When that was all finished I hot glued the new acrylic sheet in as well as the frame. This allows for much less of a disaster if I ever need to fix it again.
Step 4: Show Off the Finished Project
Overall the finished product looks really beautiful. I want to drill into the back and put some LEDs to really make it pop but that's for another day!
When using lasers, precision is just insane. It definitely did all the work, I just did my best to make it all come together. Share with your friends! Vote for me in the Fandom Contest. Watch Season three 7/4/19
Fandom Contest
Fandom Contest
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Make It Fly Speed Challenge
    4 Discussions
    seamster
    seamster
    1 year ago
    Very nice, I love it! : D
    WhenGeeksCraft
    WhenGeeksCraft
    Reply 1 year ago
    Thank you so much for your kind words. I love it too!
    JJmadigan
    JJmadigan
    1 year ago
    This is so cool! I don't know anything about laser cutters or how to use them, but this looks amazing! ST forever!
    WhenGeeksCraft
    WhenGeeksCraft
    Reply 1 year ago
    I didn't either until I got my glowforge and I couldn't be happier!
