Strawberry Cap Cake
136
Introduction: Strawberry Cap Cake
About: I'm a harpist who enjoys DIYing. ☺ DIY/Lifstyle(ish) - IG, FB: @thefischlife Harp - IG, Twitter, FB: @fischarperjr
Having a strawberry party & want something other than a sheet cake with a strawberry picture?
Try out this strawberry cap cake!
You can make it more from scratch or more from mixes. I chose the latter. :)
And let me know if you think this cake was a success or a flop.
Supplies:
Here are similar products to what I used, but you can alter it to fit your needs.
Also, you might want to use a different flavor combination...I used what was available at the time. :)
  • cake mix
  • store-bought icing
  • this frosting (Cool Whip- I think I used extra creamy...you should only need one container, gelatin)
  • green fondant
  • green icing (optional)
  • offset spatula (or whatever type of utensil you'd like to use) & knife
  • paper towels
Lookout for what I might use if I re-did the project & could choose anything!
Step 1: Bake & Make
Bake your cake in 2 layers.
You can bake them in 2 different size pans, or you can trim on layer slightly smaller.
If they crumble some when you take them out of the pans, not to worry! (See the beautiful picture above...haha). We'll slather & "glue" it together with icing shortly.
Also, start making this icing ahead of time. It needs time to chill.
Step 2: Ice
Ice the bottom later with a crumb coat, using the ready-made icing. It really helped to zap the icing in the microwave for a very brief time.
Wipe the plate around the cake with a damp paper towel after each icing coat to clean it up.
Step 3: Layer & Ice
Layer your smaller cake layer on top & frost the same way, smoothing the layers together.
Chill the cake.
Step 4: Ice Again
Now ice your cake with the frosting that you made with Cool Whip & gelatin earlier.
Chill again.
Step 5: Leaves
Roll out your fondant & cut out leaf shapes. Make veins on them with a knife.
Make a stem too.
Step 6: Add the Cap
Add the fondant leaves & stem to your cake. Mine slipped, so it might help to make the leaves thinner &/or use toothpicks to secure them (just don't let anyone eat those toothpicks!).
Step 7: Embellish
Add your darker green cookie icing to the leaf veins & cap. Spread it around with the paper towel.
This is optional, but can add a little detail.
Step 8: More Embellishing
This step is also optional, & I think I'd omit this part if I did it again. I probably needed to cover up a mistake (watch for the IGTV video to see that...).
You might want to chill the cake again before this step.
If you do want to make it look like your strawberry is coming out of grass (I realize this isn't how strawberries grow...haha!), just make a ring of icing at the base of your cake, making some drips as you go. Then, drag a knife or spatula vertically, making "grass blades."
Step 9: Enjoy & Think of Improvements
Enjoy your cake & think about what you might improve or change in the future!
Don't forget to add these DIY strawberry cake toppers if you want a little extra strawberry decoration on the strawberry cake!
(Affiliate links marked with an asterisk.)
If I re-did this project & could choose any products, here's what I might try:
*Affiliate link. If you make a purchase through on of these links, I may make a commission at no additional cost to you.
If you make this cake, be sure to tag @thefischlife & @Instructables on Instagram! And keep a lookout on The Fisch Life IGTV channel for a corresponding video.
And let me know in the comments, do you think this was a success or a fail?
Party Challenge
Party Challenge
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    2 Discussions
    jessyratfink
    jessyratfink
    1 year ago
    ahhhHhhhh!! How cute ^_^
    TheFischLife
    TheFischLife
    Reply 1 year ago
    Thank you so much! Not too bad for an amateur, eh? ☺
