Stump Block Sundial
Introduction: Stump Block Sundial
Hello my name is Matthew Moreno my goal for this project is to make a Stump Block Sundial.
Teacher Notes
Step 1: The Tools and Materials Needed for This Project
The tools materials and methods that I used were:
  • wire strippers
  • pliers
  • printer
  • tree
  • chainsaw
  • tree branch
  • drill
  • hammer
  • hot glue
  • copper wire
  • ruler
  • pencil
Step 2: How to Build the Specific Sundial That I Made
On how to build the specific you will need to go out to the woods or your backyard and cut a piece off log with a chainsaw or anything else that you can cut a tree with. Then get a thick branch cut it with pliers make sure it is not to long or short. Drill a hole in the middle of the sundial that is the width of the stick it in and then pound it in with a hammer not to hard or you will break the branch.
After doing all of that you will need to go to this app and print it the right size put it on your sundial, then you drill the screws were the Roman Numerals are. You take wire and cut it then shape it the size of that roman numeral. Then hot glue it to the sundial right above the sundial, then take a ruler and make a straight line with pencil.
Step 3: How to Use the Specific Sundial That I Built
On how to use the specific sundial that I built you will need to place the sundial on a flat horizontal surface. the number twelve numeral to point north, if it points east, west, or south, it will not work.
you can not put the sundial in a shadow from something if you do then you can't see the shadow from the gnomon (branch sticking up)
Step 4: How My Sundial Connects With the Earth
My sundial connects with the earth by the earth moving around its axis so that makes the sun move across the sky casting shadows on earth. So when the sun casts a shadow on the sundial that would be the time.
The shadow moves on the sundial because the sun is moving and every time it moves it casts a shadow from a different angle.
Step 5: The Design Process
My design process was to build a sundial without going to a store grab a round piece of wood. It was to use the materials that you have. I wanted a sundial that I can keep out in my yard one not made out of paper so when wind blows it doesn't blow away.
First I went out to the woods to cut a piece of of a tree. Second I got a thick tree branch and drilled a hole in the tree the size of the branch. Third I put roman numerals on the sundial. Fourth I put lines on the sundial and then I tested it out and it worked.
Step 6:
Step 7:
Step 8: Additional Information
If there hasn't been any sun out for a couple of days try getting a flashlight turning of the lights and shining it on your sundial.
Step 9: Conclusion
After testing my sundial I looked at the time on a clock and went outside and my sundial told the right time as the clock I looked at.
I thought this was a fun project and from this project I learned how to make a sundial and all the cool facts that you need to learn about or to make a sundial
If I were to make this again I would make the lines on the sundial much more accurate because on some of the lines were diagonal instead of straight.
Trash to Treasure
Trash to Treasure
Be the First to Share
    • Tiny Speed Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    3 Discussions
    bakichmg
    bakichmg
    11 months ago
    Thanks for sharing this. I tried clicking on your APP link and it does not work. After some trial and error I think this is it... https://www.blocklayer.com/sundial.aspx Since I just cut down some trees, I am going to try this. Thanks again!!
    matthewmoreno2019
    matthewmoreno2019
    Reply 11 months ago
    Thank you I will fix it right now
    audreyobscura
    audreyobscura
    11 months ago
    I just favorited this! Thanks for the sundial tips! I've always wanted to make one.
