Sunrise Alarm Clock (Improve Morning Wakefulness)
Introduction: Sunrise Alarm Clock (Improve Morning Wakefulness)
About: 3D printing and designing RaspberryPI projects for a few years now
Schedule your own personal sunrise, improves morning wakefulness
Latest random invention, schedule your own sunrise!
During the day, the blue light in sunlight boosts our attention, memory, energy levels, reaction times, and overall mood. Blue light suppresses the release of melatonin, for morning use only :)
Step 1: Flashing RaspberriPi Hard Disk / Install Required Software (Using Ubuntu Linux)
Download "RASPBIAN JESSIE LITE" https://www.raspberrypi.org/downloads/raspbian/
Create your new hard disk for DashboardPI
Insert the microSD to your computer via USB adapter and create the disk image using the dd command
Locate your inserted microSD card via the df -h command, unmount it and create the disk image with the disk copy dd command
$ df -h /dev/sdb1 7.4G 32K 7.4G 1% /media/XXX/1234-5678 a
$ umount /dev/sdb1
Caution: be sure the command is completely accurate, you can damage other disks with this command
if=location of RASPBIAN JESSIE LITE image file of=location of your microSD card
$ sudo dd bs=4M if=/path/to/raspbian-jessie-lite.img of=/dev/sdb
(note: in this case, it's /dev/sdb, /dev/sdb1 was an existing factory partition on the microSD)
Setting up your RaspberriPi
Insert your new microSD card to the raspberrypi and power it on with a monitor connected to the HDMI port
Login
user: pi pass: raspberry
Change your account password for security
sudo passwd pi
Enable RaspberriPi Advanced Options
sudo raspi-config
Choose: 1 Expand File System
9 Advanced Options
A2 Hostname change it to "SOLARLAMP"
A4 SSH Enable SSH Server
A7 I2C Enable i2c interface
P4 SPI Enable/Disable automatic loading of SPI kernel module
Enable the English/US Keyboard
sudo nano /etc/default/keyboard
Change the following line: XKBLAYOUT="us"
Reboot PI for Keyboard layout changes / file system resizing to take effect
$ sudo shutdown -r now
Auto-Connect to your WiFi
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Add the following lines to have your raspberrypi automatically connect to your home WiFi (if your wireless network is named "linksys" for example, in the following example)
network={ ssid="linksys" psk="WIRELESS PASSWORD HERE" } Reboot PI to connect to WiFi network
Now that your PI is finally on the local network, you can login remotely to it via SSH. But first you need to get the IP address it currently has.
$ ifconfig Look for "inet addr: 192.168.XXX.XXX" in the following command's output for your PI's IP Address
Go to another machine and login to your raspberrypi via ssh
$ ssh pi@192.168.XXX.XXX
Start Installing required packages
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get install memcached vim git python-gpiozero python-smbus i2c-tools python-imaging python-smbus build-essential python-dev rpi.gpio python3 python3-pip python-memcache python3-spidev python-spidev
Update local timezone settings
$ sudo dpkg-reconfigure tzdata
select your timezone using the interface
Setup the simple directory l command [optional]
vi ~/.bashrc
add the following line:
alias l='ls -lh'
source ~/.bashrc
Fix VIM default syntax highlighting [optional]
sudo vi /etc/vim/vimrc
uncomment the following line:
syntax on
Install i2c Python Drivers
Install the NeoPixel Driver as follows
sudo apt-get install build-essential python-dev git scons swig
sudo pip3 install --upgrade setuptools
sudo pip3 install rpi_ws281x
cd rpi_ws281x
scons
cd python
sudo python setup.py install
cd examples/
sudo python strandtest.py
Step 2: Supplies Needed
5V Power Supply
I2C 7 SEGMENT
Microchip MCP3008
Momentary Tactile Tact Push Button Switch [x5]
PI ZERO W
Logarithmic Slide Potentiometer
WS2812B Individually Addressable RGB LED Strip [x4]
Thin Plexi Glass Sheet
Frosted Spray Paint
Step 3: 3D Print the Controller Panel
Using the .x3g files included in the "3D Print/" folder print the main control panel cover, which will house the slider, buttons, LED and 7 Segment display
Step 4: Building the Lamp
Build Wood Frame
I've built a wooden frame for the LED strips to be enclosed in and painted it black.
Paint Plexi Glass
With some frosted spray paint, paint the glass so that it defuses the light from the strips.
Mount Strips
Using simple tape and the stickiness of the backside of the LED strips, mount the 4 strips to the wooden base
Step 5: Mount Buttons
Mount the buttons and the yellow LED, I've used hot glue to hold the buttons and LED in place.
Step 6: Mount Chip on the Slider
Following the provided schematic, solder the chip wiring in place and connect to the logarithmic slider, glue the chip with solder connections to the back of the slider.
Step 7: Wiring the Components
Use the following Schematic to connect all the components to have the lamp work properly.
Step 8: Wire Panel
Connect all wiring to the components glued on the panel to connect to the raspberrypi.
Step 9: Wire Pi
Finally attach the PiZero to the back board of the LED wooden case with tape or glue and then connect the wiring according the provided schematic.
Step 10: Mount Panel
Fasten the control panel on the bottom of the LED case.
Step 11: Apply Plexi Glass
Attach cut and painted plexi glass to the LED case with screws
Step 12: Mount on the Wall
Step 13: Finished!
Set pi user crontab
Enter the following line for a minute by minute crontab
$ crontab -e
0 3 * * * python /home/pi/SolarBar/Alarm.py > /dev/null 2>&1
@reboot python /home/pi/SolarBar/Buttons.py > /dev/null 2>&1
@reboot python /home/pi/SolarBar/ControlPanel.py > /dev/null 2>&1
@reboot python /home/pi/SolarBar/Slider.py > /dev/null 2>&1
Set root user crontab (this library requires root access) Set "on reboot" to run the candle python script forever
$ sudo su
$ crontab -e
@reboot python /home/pi/SolarBar/LEDs.py > /dev/null 2>&1
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
