Introduction: Super Cheap IPhone Stand!!!!!
Materials: All you need is a paper clip and needle nose pliers.
Step 1: Lets Start!!
Get a big paperclip and bend it so its straight.
Step 2: Lets Start to Build
Make a line on a paper with 8mm from 8mm measure 33mm from 33mm put 30mm from 30mm put 11mm from 11mm put 30mm from 30mm put 33mm. If you get confused look at the pictures.
Step 3: Lets Do This!!!!!!
Bend the top at 11mm bend the sides at 30mm which makes the bottom part 33mm then bend the last two bends at 8mm. Then your done!!!!!'
Pocket Sized Contest
