Super Easy Copper Jewelry
Introduction: Super Easy Copper Jewelry
use this instructable to make easy jewelry with a variety of wire in a multitude of gauges and metals
Teacher Notes
Step 1: Choose Wire
Your wire can be anything so long as it holds its shape. Choose your wire it can as thick or thin as you want i chose a long piece of copper grounding wire
Step 2: Straighten Wire
Make sure your wire is straight to make it easier for yourself in the long run also cut the wire about 2 and a half or 3 inches long also get a socket about as thick as the ball of your finger to make wrapping easier
Step 3: Wrap Wire Around the Socket
Wrap the wire around the chosen socket dont worry about overhang there is bound to be some
Step 4: Finish Work
Cut off the overhang and file the ends to even them you can solder the ends togeather if desired. Then sand the whole ring until it shines work up from low to high grits i finished at 1500
Step 5: Enjoy Your Ring
You have a finished ring if you have any better ideas please leave them in the comments im open to suggestions
Be the First to Share
    • Finish It Already Speed Challenge
    • First Time Author Contest
    • Leather Challenge
      Leather Challenge
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Copper looks like a fun material to work with :)
