Super Mario Brothers World One
Lets Get Started!
Teacher Notes
Step 1: Generate or Find a Picture Reference of the Super Mario World World One Island.
find your picture
Step 2: Using the Reference Photo, Create Different Aspects of the Picture in TinkerCad, or Any 3D Modeler of Your Choice. ( Hills, Ladder, Castle, Rocks, Etc. )
make sure to use tinker cad
Step 3: Gather Materials
These are the recommended materials that you use, however, it will work with other materials if you can’t get your hands on some of these things.
Green/Gray 3D Printer Filament
Access to a 3D Printer
Green Blue, and Yellow paint
Paintbrushes
Box cutter
Foamboard
Hot glue
12oz soda bottle
sandpaper
Step 4: Begin to 3D Print Your Pieces Using the 3D Modeler You Used Earlier.
make sure to watch the printer while it works
Step 5: Take Your Foam Board and Cut Out a 7x7 Inch Piece.
use the box cutter
Step 6: Trace the Base Landscape With a Pencil
lightly in case you have to erase
Step 7: Begin by Painting the Outside Area With Light Blue Paint
repeat till no brush strokes are left noticeable
Step 8: Using the Green Paint, Paint Inside the Traced Lines
repeat till no brush strokes are noticeable
Step 9: Take Your EMPTY Soda Bottle and Cut Off the Bottom to the Desired Height
try and keep it even!
Step 10: Sand the Entirety of the Bottle Very Slightly (helps the Paint Stick) and Begin to Paint From the Ridges Down in Yellow.
sand lightly
Step 11: Paint the Rigid Top of the Bottle Green.
Use enough coats so it is no longer transparent.
Step 12: Glue Everything Down
Glue the bottle (AKA the “hill”), to the back left corner of the green area
Hot glue the little hills/ objects you designed and 3D printed earlier in desired pattern. (Make sure they stay on the green part of the foam board though.)
Step 13: (optional)
Cut out 3 7x7 inch squares
Paint one side light blue (Repeat for all three boards.)
Take a fluffy paintbrush, add a small amount of white paint, and dab it in a cloud-like motion.
Glue sides on with the blue sky facing inward.
Step 14: Enjoy Your Brand New Mock-up Model of a Super Mario World Island!
Yay!
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
    seamster
    13 days ago
    Neat project, thank you for sharing! : )
