Introduction: Super Simple DIY Coffee Table Made From (PVC) Waste/Drain Pipe and Fittings
I wanted to make a smaller table which could be used as a coffee table as well as a table for kids. I searched a lot for a quicker and easier way to make such a table but could not find any instructions online. So I thought about it and came up with a way to make the table. I would like to share with you how I made the small table.
The frame was made using the plastic (PVC) waste pipe and pipe fittings (32 or 40 mm diameter) mainly used for bathroom/kitchen waste/drains. I bought these parts quite cheap from a trade DIY shop. In UK these type of pipes and fittings are called solvent weld pipe and fittings. Solvent weld means they can be stuck/attached with solvent cement (also known as PVC Glue).
This is what the finished table looks like :)
Disclaimer:
All the instructions are provided "as is". This is a Do It Yourself (DIY) instructable and involves using mechanical tools such as a pipe cutter, drill etc. These tools can cause harm if not used with proper care, please follow these instructions at your own risk; I will not be liable for anything what so ever.
Step 1: Components Required
- Solvent weld (PVC) pipe black, 32 mm diameter
- Solvent weld (PVC) 90 degree conversion
- Solvent weld (PVC) Tee, 32 mm
- Solvent weld (PVC) access plug
- Solvent weld (PVC) straight coupling 32 mm
- Solvent Cement (PVC Glue)
- About 5 mm MDF wood for the top
- Any nice decoration (paper or paint etc.) to go on the top. I applied self adhesive paper with a cool zebra print.
- A thin (2.5/3 mm dia) screw and nut
Step 2: Tools Required
- Drill with a wood drill bit
- Screw-driver
- A wood saw (manual, hand one or powered) or get the wood already cut
- Plastic, waste pipe cutter
Step 3: Creating Legs of the Table
- Applying solvent to a 32 mm straight coupling to make a joint with the access plug.
- Then applying solvent to the straight coupling and the pipe cut to the size of the table leg that you require in order to create the leg of your table.
- Now one leg of your table is ready. You have to make 4 of these :).
Step 4: Attaching the Legs
Please be careful while using these tools.
- In order to create the base of the leg where the leg can be attached, unscrew the cap of the access plug and stick it on to the under side of the wooden top of the table.
- I also drilled a hole through the top and the plastic cap and passed a screw and fixed it with a nut on the bottom side.
- The leg then is screwed onto the cap of the access plug which we stuck on the back side of the table top before.
Step 5: Stabilizing the Legs
- Now apply some solvent to the Tee to create a stabilized leg.
- The main reason behind creating such a base at the end of the table leg is so that the table can easily slide on the carpet or laminate floor. This also stabilizes the table and gives strength to its structural integrity.
Step 6: Creating a Leg Rest and Strengthening the Frame
- In order to create the middle support and leg rest, 3 Tees are stuck together as shown in the image, by applying solvent to the Tees and small pieces of pipe to link and interconnect them.
- The 90 degree conversion is then stuck to the middle Tee. This forms one end of the leg rest in the middle of the table.
- Then pipe is cut and stuck to the 90 degree conversion on one end, length wise to create the leg rest.
- Similarly the other end of the leg rest is created using the Tee and the other 90 degree conversion.
- This structure serves two purposes, a nice leg rest and provides much required structural strength to the table
- Since there are many ways you could make the legs and the frame of the table, I leave it to you to use your imagination and creativity to enhance or modify the table.
- Finally the table is ready. So easy to make, so quick to make.
Wood Contest 2016
Maker Olympics Contest 2016
