Super Strong Bowler-Style Bag
5,979
28
12
About: Welcome! Pleased to meet you, I am Barb; a Maker. I have been making things AND explaining how to make things for as long as I can remember. I was all about DIY before it was a popular term. I absolutely lov...
Yes, it may look pretty but don't be fooled; it's super STRONG! You know how great denim is and this is made with many many layers of denim.
It's not a bought fabric print; it's all original design in sewing; free-motion technique. I personally hate wimpy slouchy purses but I also don't have a professional machine to sew cowhide so that's what led to this design, as it employs the fact that the 'Roses' are actually making the fabric much stronger than it was. Who says utilitarian needs to be ugly?!
As for supplies, much can come from upCycling!
Supplies:
  • Various pieces of denim/old jeans
  • Threads of various Blues
  • Scissors/Rotary cutter
  • 4 - 1" D-Rings
  • Pins or clips
  • 2 Zippers (at least 12", over-length are fine)
  • 1/4 yard Fusible Web
  • 2 - Clasp-Clips with 1" ends
  • Sewing Machine with basic presser foot
  • Free-Motion (darning) Presser foot
  • 5-6" Zipper
  • 1 yard of 1/4"ID vinyl tubing
  • Lining Fabric
  • 8" of 1/4" ribbon
  • Thin leather or Imitation Leather (trim, straps & bottom)
Teacher Notes
Step 1: Pattern & Basic Side Pieces
First, you will need the pattern! I made sure the pattern worked out and it's available to download here:
Make sure you print it without scaling and notice the fold lines (place on fold)
  1. Cut the 2 side pieces out of denim, make slightly (1/2") oversized at first (to allow recutting after quilting)
  2. Double if added strength is desired
  3. Assemble a variety of blues of denim scraps
  4. Iron some fusible web to the back of these pieces (about 6" x 8" pieces)
  5. Use backing sheet provided or parchment paper to avoid it sticking to iron
  6. Notice fabric now has a shiny back layer which makes it now able to be adhered by ironing
Step 2: Creating the Images & Strengthening Sides
This 'Rose' pattern is really easy as they are just odd shapes of varying tones of blue. Any geometric shape can also work if flowers are not your thing. This is called Art Quilting.
  1. Cut random 'squiggles' and place on fabric
  2. Cut leaf shapes as well
  3. Look at images of roses for inspiration
  4. Keep Lighter & larger pieces on outside of shapes
  5. Using Parchment paper Iron to adhere to fabric
  6. Adjust Sewing machine to settings for darning (ie, feed dogs lowered) and install free-motion/darning foot or another method depending on machine (most can adapt in some way)
  7. Move fabric around while sewing, somewhat like 'doodling' with a sewing machine. Don't be too fussy as it's supposed to look sketchy!
  8. Using different colours of thread will add interest as well.
  9. Admire your roses!
Step 3: Adding the Zippers
Using the Pattern again, recut to exact size. This pattern is a great shape as it sits flat and has minimal pieces. Less pieces means less chance of breakage.
  1. Cut Zipper at end stops and melt with lighter to stop fraying
  2. Mark top center (notch) and sew 1 zipper from center top on each side
  3. Leave extra zipper length for now
Step 4: Making & Adding the Handles
This purse has to short handles as well as a cross body option
  1. Cut 2 17.5" x 4" pieces of 'leather' and double fold, sewing at the edge (check to see that tube will allow to slide in freely)
  2. Slide Vinyl into strap
  3. Secure the D-rings by folding over at ends and sewing multiple times
  4. Make tabs by folding over and inserting ribbon as sewing to add extra reinforcement (*tip from the professionals)
  5. Mark Placement of tabs with tape
  6. Sew tabs into place (rivets can be used if desired) with multiple lines of sewing to reinforce
  7. TADA! Handles!
Step 5: Adding Inside Pockets to Lining Pieces
Cut Lining & pocket pieces. This design has one patch pocket and one zippered
  1. Cut the pieces for the pockets
  2. Double the zipper-pocket piece with the lining and stitch the slim rectangle
  3. Cut the middle and into the corners
  4. Turn and press
  5. Center the zipper in the 'hole' and sew zipper all around
  6. Fold up bottom piece and stitch sides & top.
  7. Finish top edge of patch pocket with double fold over and fold around outside.
  8. Stitch on 3 sides
  9. Pockets done!
Step 6: Adding Lining to Sides
Since this bag is basically 3 pieces (2 sides and bottom) a triangle at the side helps keep contents in and open wide. It is not totally necessary as it is a bit fussy to get/sew in place.
  1. Cut 2 triangular pieces
  2. Finish top edges by sewing fold-over
  3. Pin/clip in place right sides together at bottom side seam
  4. Place lining over one side (right sides together) and sew same line as was used to sew in zipper
  5. Turn right side out
  6. Tricky part: On second side, place finished side inside making sure to position the triangle properly and sew same seam line as zipper. Tip; if sewing from side where stitch line is visible, easier to see/sew stitch line.
Step 7: Adding Bottom Trim
Turn the sewn sides right side out and steam press well flat to keep lining in place
  1. Check for fit of long strip around bottom of bag
  2. Sew centre seam of strip
  3. This strip is folded over (for strength)and top stitched around entire bottom of bag
  4. Stop before & after zipper
Step 8: Adding Bottom Piece
Once the trim is added it is now almost done.
  1. Cut one (or 2, if extra durability is wanted) bottom pieces marking centers.
  2. Optional; top-stitch if using 2 pieces to further reinforce
  3. Clip around trim piece at less than seam allowance (1/2") around entire pice about every 3/4" (trick to sew in any curved piece)
  4. Pin/clip in place right sides together matching centres and ease as needed
  5. Sew around oval bottom
  6. Trim to small seam for less bulk
Step 9: Bottom Lining
To finish it off without any seams showing the bottom lining is hand stitched
  1. Turn bag inside out
  2. To stiffen the bottom cut a styrofoam meat tray (or any thin plastic) to oval shape of bottom
  3. Pin bottom oval in place matching centres
  4. Sew a running stitch around and slip plate in before closing
  5. Neat and finished bottom
Step 10: Oh, the Details!
I like to make it look professional so small details matter!
  1. Sew a very thin strip of folded 'leather' (tip; to make sewing easier use a wider piece and then trim after)
  2. Tie strips into zipper pulls
  3. To hide any raw edges use a marker (or paint) to colour
Step 11: Cross Body Strap
Decide how long a strip (4x folded = 4" wide) you would like for your cross body taking in account the clips.
  1. Fold over double strip and top stitch each side (you can also up-cycle an old belt)
  2. Slip on clasp-clips and stitch multiple lines for strength
  3. Clip to D-rings on alternate sides
  4. Marvel at your new purse!
Step 12: Enjoy Your Bag!
Are you not amazed at how great this bag looks for so few pieces! It is inspired by bowling bags but is the best shape for a purse. I love how it sits so nicely and stays sturdy! Not to mention that it will always look great with the wardrobe of choice; jeans!
You could make a smaller version by printing the pattern smaller (seam allowance will also be smaller)
There's a special feeling by carrying an original 'designer' purse!
See more purses and projects one my site or one that uses no sewing
Happy making! Let me see how your's turns out...
Sew Tough Challenge
Second Prize in the
Sew Tough Challenge
    • Make It Fly Challenge
    • Stone Concrete and Cement Contest
    • Spicy Challenge
      Spicy Challenge
    12 Discussions
    KirstenR10
    21 days ago
    Love it! I'm not much of a sewer but I love free motion stitching with my machine and always use recycled clothes from the op shop to make other things. Not sure I'd make as lovely a job of this as you have but it inspires me to keep trying. Thank you for sharing!
    LindaMick
    23 days ago
    I'm planning to make this as a bag for my new Juki coverstitch machine.. been looking for how to make a bag extra study. I'll adjust the size and put plastic on the bottom for stiffness and of course it won't look as pretty, but will work. Thank you!
    pattymadeit
    25 days ago
    Oh! My! Goodness!!!!
    I FRIGGING LOOOOOVE THIS!!!!!
    I make many purses, AND, I up-cycle lots of denim jeans into things, including purses. THIS is something new for me. I have never seen anything like this! My brain is already buzzing 100 mph! ha I WILL be using this denim technique soon! Thank you for sharing! :-)
    MadeByBarbpattymadeit
    Reply 24 days ago
    Yes, it's great as the simplicity of just using the tones of denim makes the designing easy. I love that it can be such a stiff fabric now. I get the 100MPH! I'm always so excited about some new project! I bet you would love Eco Printing!
    attosa
    27 days ago
    Absolutely stunning! I love your work. Thanks for sharing your steps!
    MadeByBarbattosa
    Reply 27 days ago
    Thanks! I've been meaning to use this method to make a quilt but this way I'll get to use it everyday!
    snowf7MadeByBarb
    Reply 24 days ago
    This is a great design. It can be made with so many variations. My mind starts to race thinking of skirts, aprons, placemats, runners. Thank-you so much for sharing this with us. To make the bottom of the purse more sturdy without the fear of the foam tray cracking, a piece of thicker leather would work or even a double layer of plastic from a large jug. Better yet a piece of plastic from a crazy carpet. They will probably be available at all the dollar stores in the late fall.
    This design would make a beautiful Rose Crazy Quilt to further honour your friend. Rather than denim, you could also make one out of flimsy pastel fabrics for summer. If you made two light weight ones, you could stitch them together with wrong sides together using the free motion technique and then complete it with a silky/satin/ribbon border in colours to pick up on the fabrics used in the body of the quilt.
    MadeByBarbsnowf7
    Reply 24 days ago
    Oh yes, you are like me... I am barely done and wanting to make another version already! As an illustrator this is just too tempting and I love the power of 'petal-to-the-metal foot control! Like driving!
    MaraCreates
    24 days ago
    Beautiful, great job on the FMQ roses, they make the bag look so pretty.
    MadeByBarbMaraCreates
    Reply 24 days ago
    Thanks! That style of free-form should easily manageable for most sewers, but really the sky is the limit. Imagine just triangles or spiral circles or rectangles.
    WeTeachThemSTEM
    27 days ago
    I love the rose pattern you created and overall sturdiness this purse seems to have! Thanks for sharing your process!
    MadeByBarbWeTeachThemSTEM
    Reply 27 days ago
    A very special person in my life was named Rose. This is a tribute to her and the amazing inspiration she gave me. I'm sure she must be pretty happy to see it...
