Introduction: Super Fast LAMP Install on CMD Line Linux
This is the fastest command line method I use for installing the LAMP stack. I use server1 as a hostname and 192.168.0.100 for and IP, use what you are using on your machine if you have a static or DHCP.
Login to your installed Linux workstation.
Install MYSQL
prompt-> yum install mysql mysql-server
Create system startup links for MySql
prompt-> chkconfig --levels 235 mysqld on
prompt-> /etc/init.d/mysqld start
Lets setup the passwords for MySql root account.
prompt-> mysql_secure_installation
To login you need the current password for root user, if just installed (we just did it) it will be blank for the account, press enter.
Setting the root password ensures no bad things can happen.
"Set root password -
New password -
Re-enter new password -
Password updated!
Reloading priviledge tables...
…Success!”
By default MySql comes with an anonymous user, lets remove it.
"Remove anonymous users? -
....Success!"
"Disallow root login remotely -
...Success!"
"Remove test database and access to it -
- Dropping test database... ... Success! - Removing privileges on test database... ... Success!"
'Reload privieldge tables now -
...Success!"
All done!
Now lets install Apache2
prompt-> yum install httpd
Set the startup
prompt-> chkconfig --levels 235 https on
and start it
prompt-> /etc/init.d/httpd start
Point your local browser to local IP http://192.168.0.100 or whatever you are using.
You should get default installation page, success!
Now lets install PHP5
prompt-> yum install php
Restart apache
prompt-> /etc/init.d/httpd restart
Test php5
prompt-> vi /var/www/html/info.php
phpinfo(); ?>
Save file,
Now we call that file in a browser (e.g. http://192.168.0.100/info.php)
Success!
Now lets install MySql PHP5 Support
prompt-> yum search php
Pick the items you need and install them like this:
prompt-> yum install php-mysql php-gd php-imap php-ldap php-mbstring
php-odbc php-pear php-xml php-xmlrpc
Now lets restart Apache2:
Now reload http://192.168.0.100/info.php in your browser and scroll down
to the modules section again.
You should now find lots of new modules there, including the MySQL module:
phpMyAdmin phpMyAdmin is a web interface through which you can manage your MySQL databases.
First we enable the RPMforge repository on our CentOS system as phpMyAdmin is not available in the official CentOS 6.2 repositories:
Import the RPMforge GPG key:
prompt-> rpm --import http://dag.wieers.com/rpm/packages/RPM-GPG-KEY.dag.txt
On x86_64 systems:
prompt-> yum install http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.2-2.el6.rf.x86_64.rpm
On i386 systems:
prompt-> yum install http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.2-2.el6.rf.i686.rpm
phpMyAdmin can now be installed as follows:
prompt-> yum install phpmyadmin
Now we configure phpMyAdmin. We change the Apache configuration so that phpMyAdmin allows connections not just from localhost (by commenting out the stanza):
prompt-> vi /etc/httpd/conf.d/phpmyadmin.conf
# # Web application to manage MySQL #
# # Order Deny,Allow # Deny from all # Allow from 127.0.0.1 #
Alias /phpmyadmin /usr/share/phpmyadmin Alias /phpMyAdmin /usr/share/phpmyadmin Alias /mysqladmin /usr/share/phpmyadmin
Next we change the authentication in phpMyAdmin from cookie to http:
prompt-> vi /usr/share/phpmyadmin/config.inc.php
[...] /* Authentication type */ $cfg['Servers'][$i]['auth_type'] = 'http'; [...]
Now we restart Apache:
Afterwards, you can access phpMyAdmin under http://192.168.0.100/phpmyadmin/:
To allow external connections to your machine you will probably have to adjust your firewall and allow external connections to the service.
Now you are ready for any other items like wordpress, cubet board, joomla, or any other mysql php driven softwares.
