Super-slim, Cool-lookin, EMI-shielding Wallet
28,923
19
19
Introduction: Super-slim, Cool-lookin, EMI-shielding Wallet
Ever get tired of carrying around a huge honkin' leather wallet?
Want to impress your hipster friends with your wacky style?
Worried about your credit cards getting erased by all those stray electromagnetic fields you've been hearing about?
Then this is the wallet for you.
Teacher Notes
Step 1: Cut Pieces
grab the anti-static bag that your CD-ROM burner came in, and cut it into tiny pieces.
9 pieces 2.3" by 4.5"
1 piece 4.5" by 9"
Step 2: First Pocket
tape two pieces together, with their long edges 0.4" apart. Sew them along the opposite edge.
Step 3: Second Pocket
do it again: Another piece, offset by 0.4" along the long edge. Sew along the other edge
Step 4: Third Pocket
do it once more
Step 5: Make the Second Set of Pockets
make another set of pockets, just like the first set
Step 6: Join the Two Sides
Put the two sets of pockets back-to-back, with the last piece of plastic between them. Make sure the last piece sticks out 0.4" along the long edge. Tape the long edges in place.
Now, fold back three pockets on each side, and run a single seam, 0.4" from the left edge as shown.
Step 7: Sides of Pockets
Run two seams from the top down to about the middle of the wallet, on each side, as shown.
These are finish seams, so make sure you do the reverse trick at the ends.
Step 8: Attach Outer Flap
Attach the outer flap by sewing a three-sided seam as shown. This is also a finish seam, so make sure to reverse at both ends.
Also: Be sure not to go too far up near the top of the wallet; if you do, your money pocket will be very tight.
Step 9: Trim
Trim around all your seams. Turn the wallet over and trim the outer flap to your desired shape.
Step 10: Load and Go!
Put your most used cards in the front pockets.
Put your least used cards in the back pockets.
Put your money in the money pocket.
You're all set to go, in lush, slim, silvery, EMI-proof style!
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Indoor Plants Challenge
    19 Discussions
    saulallen
    saulallen
    3 years ago
    Really like this
    mmer2007
    mmer2007
    5 years ago on Introduction
    I'm an upholsterer so I'm a little particular about stitching.
    Some Suggestions:
    1. Increase your stitch length. The material between close stitches has a tendancy to tear. It'll still hold and be more aesthetically pleasing.
    2. Reduce the thread tension. The thinner the material, the less tension you need.
    Practice on scraps before you begin your project to find the perfect balance!
    tabornakz
    tabornakz
    11 years ago on Introduction
    fortunately, I amaze with ur idea..thx for the idea...hmmmm...its smell money. better to make business with it...
    ringleader369
    ringleader369
    11 years ago on Step 1
    ...what a spiffy idea!!...my dad has a bunch of that lying around......hmmmm might make wallet....THANKS........giving you a good rating
    ian_fleming007
    Tweeks is right...it must be made of wire mesh. I found this site http://www.rfidblockr.comThere wallets, passorts covers are made of copper mesh that creates a true faraday cage. DIFRwear only uses tinfoil in their products but it still works but http://www.rfidblockr.com I think will last later because it is copper wire mesh.
    stranoster
    stranoster
    13 years ago
    maybe adding a clip from a 9v battery halved and on a strip like on the wraparoundish things to shut it? I dunno but Great Instructable! My wallet was getting lame!
    place name here-
    place name here-
    13 years ago
    Nice cool instructable dident quite understand it all but cool.
    JonC
    JonC
    13 years ago
    i know this is old, but still point 1 : this material is indeed electrically conductive to prevent static, static often charges to many thousands of volts this material is designed to prevent that. Point 2 : A EMI sheilding pouch for mobile phones?! Mobile phones for by EM radiation, so wrapping your phone in shielding would block it from getting any signal too...
    mrtools
    mrtools
    14 years ago
    are there other places i can get this meterial besides as a packing material
    joncas
    joncas
    Reply 13 years ago
    You can try the Shieldon fabrics: www.shieldon.com
    joncas
    joncas
    13 years ago
    Try theas shielding fabrics: www.shieldon.com. It might work
    pmetro
    pmetro
    13 years ago
    check out these sites refered by wservernews.com newsletter
    https://shop.foebud.org/product_info.php/cPath/30/products_id/58
    http://www.difrwear.com/products.shtml
    http://www.wservernews.com/EQE61C/060417-RFID_Zapper
    how about clothing and accessories that are shielded for persons concerned about EMI, RFI shielding and RFID crackers, etc. ??? marketable ???
    sample ad "only wear clothing and accessories that carry the ------- logo to protect yourslf from EMI RFI emmisions.
    cell phones with shielded enclosures to protect against blue tooth sniffers and RFID crackers....
    pmetro
    pmetro
    14 years ago
    has any one tried making a shielded pouch for cell phones ?
    The Dragon Master
    The Dragon Master
    14 years ago
    If you are looking for an RFID blocking wallet, try http://www.i-hacked.com/content/view/208/48/. It's an article about how to make an RFID blocking wallet using aluminum foil and duct tape. Haven't tried it myself though. I don't use any RFID cards so I would have no way to check. Though I like this idea. I am making a tri-fold version of this wallet. I like that the material will be much thinner than the leather wallet I currently use.
    tweeks
    tweeks
    14 years ago
    That stuff is for ESD (electro static discharge) protection. Not EMI or RFI protection. If you want to stop RFID waves, you will need a wire mesh with a mesh size 1/4 (or smaller) than the frequency wave length. In your case.. regular window screen should be fine.. but is not flexible. Google for "Faraday Cage" to get an understanding behind the tech. This is.. if you you want to build something more than just a shiny wallet. ;) Tweeks
    vaiodon
    vaiodon
    14 years ago
    That material isn't EMI shielding, it's simply electrically conductive so as static charge doesn't build up on electronic devices that aren't in situ, connected to power and, consequently, have a path to earth/ground.
    EMIExpert
    EMIExpert
    14 years ago
    Looks cool... don't expect it to actually work, though. I tested the material using a closed bag with my RFID security access card and it made zero impact on the distance the card was detected from the reader. The material is static dissipative, but not EMI blocking in the frequency range used by RFID cards. Magnetic fields are not affected by this material either, so it cannot protect the mag stripes on your credit cards, etc. Highly conductive metal foil (iron/steel for magnetic shielding) is needed for EMI shielding.
    ehmbee
    ehmbee
    14 years ago
    Cool idea-I recently experimented with this material... I found the thin heat sealing wire on one of those home vacuum sealers will bond this stuff together perfectly! May save you on some stitches, or to make sealed bags for larger items you may want to protect from EMI. ehmbee
