T-Track Assembly Table/Outfeed Table
About: My name is Brandon. I am a woodworker and content creator. I have a business building custom furniture for clients but I also create DIY style content on YouTube and other platforms. Hope you guys enjoy! ...
Teacher Notes
Step 1: Assembling the Top
I started out with 2 - 4' x 8' sheets of 3/4" sanded ply and one sheet of MDF. I rough cut them all down to just a little over 6' x 4'. Then I laminated them all together with glue and screws, making sure the MDF was on top. (I used a flush trim bit in my router after laminating each one to make it all nice and flush.)
Side Note - If I were to do this again I would probably just go with all plywood. Personal preference.
Step 2: Cutting Material
At my buddy Oscar's shop we used a combination of his track saw and table saw to cut all the pieces for the cabinet carcasses.
We made sure to label each one!
Step 3: Drilling Pocket Holes
I moved onto drilling pocket holes with the Kreg Foreman. (also Oscars) Super quick and easy. I need one of these things!
Step 4: Routing for the T-Track
Using a 3/4" bit in Oscar's router I cut the slots for the t-track in 3 depth steps. The cool thing about this system is the router attaches to the track for the track saw. Makes it super simple to keep everything straight.
Step 5: Carcass Assembly
Back at home I started assembling all the cabinet carcasses individually. One side houses pull outs for systainers, the other houses my shop vac/dust separator, and the end cabinet has 4 wide drawers in it.
Step 6: Cutting Drawer Stock
I then turned my attention to cutting the drawer stock. I used 3/4" ply for the sides, false front and back. I used 1/2" ply for the drawer bottoms.
A dado stack is a simple way to cut the 1/2" slots in the two sides and back for the drawer bottoms.
I also used this time to cut the overlay drawer fronts.
Step 7: Drawer Assembly
Using pocket screws and glue I put the sides and back together then slid the bottom in the dado slot. I then attached the front.
Step 8: Installing the Drawers
Using spacers I installed the Accuride drawer slides per instructions and then in went the drawers! These are soft close slides and it makes it so nice!
Step 9: Installing Drawer Fronts.
I put a chamfer around all the drawer fronts just to give it a little character.
Then to install the fronts I used glue, spring clamps and screws from the backside.
Step 10: Backs
I cut and installed backs for all the cavities using glue and brad nails.
Step 11: Installing Pull Outs
Using under mount slides I installed the pull outs for the systainers.
Step 12: Doors
I cut the material for the two doors on the cabinet that will house the vac and dust collection. Using this awesome kreg hinge jig I cut the holes for the hinges. This thing works awesome! Also these hinges work really well.
Step 13: Making the Base
I created an adjustable base for the assembly table and using these adjustable feet worked amazing! I just made it out of the same 3/4" ply I used for the rest of the table putting in bracing and also some pieces to screw the cabinets to once installed.
Step 14: Installing the T Track
I cut all the pieces of the T Track and dry fitted it all. I used the pre made intersections which helped a ton! Once it was all dry fit I went over everything with a small round over bit and then installed the t track.
Step 15: Setting Up the Base and Attaching Cabinets
I leveled out the base as well as I could, set the cabinets on it, attached them to it and also screwed them together,
Step 16: Attaching the Top
Making sure it was centered I attached the top with screws from underneath all the way around.
Step 17: Coming Together
I reinstalled the drawers, pull outs and snapped the doors back on.
Step 18: Side Trim
I decided to use walnut for the edges because I love the way it looks with the blue T Track in it. I did this so I could hold pieces vertically to work on. It works very well. Using my dado stack I cut the 3/4" slot for the track in the trim pieces. I used glue and brad nails to attach the trim.
Step 19: Cutting Corners....
Cutting the corners off does a couple things... You wont injure yourself running into them and also it allows space for the clamps to slide in and out.
Step 20: Installing Pulls
I also used walnut and made my own drawer pulls and pull out fronts. I cut a 45 degree finger hold on the bottom of the pulls.
I didn't capture it but I also used the drawer pulls as the cabinet door handles.
Step 21: Finishing
I used boiled linseed oil and it looks really good. HOWEVER, if you do use MDF for the top I would suggest using poly or something else. The linseed oil soaked in really bad and left a kind of uneven finish on the MDF.
Step 22: Installing the Side Track
Then I could install the T Track on the trim pieces. I decided to only put it on two sides but you can put it all the way around if you would like :)
Step 23: Finished!!!
All in all I really enjoy using this table on a daily basis! I left the systainer area open on the right to add more later. Thanks so much guys for making it to the end. Don't forget to watch the build video for more detail on the build and if you want to build one yourself as well as support me doing what I love consider purchasing the plans I had professionally made. They are VERY detailed and laid out great. Thanks again and I will see you on the next build!
FULL BUILD PLANS - Click for plans
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
