TOUCH SWITCH | How to Make a Touch Switch Using a Transistor and Breadboard.
Introduction: TOUCH SWITCH | How to Make a Touch Switch Using a Transistor and Breadboard.
About: .Founder of @PIYSocial. A Student interested more towards Digital Language. YouTuber @PIYSocial. Innovator and National Awardee in various Science Fields.Curious about how things work and interested to make ...
The touch switch is a very simple project based on the application of transistors. The BC547 transistor is used in this project which acts as the touch switch.
MAKE SURE TO WATCH THE VIDEO WHICH WILL GIVE YOU THE FULL DETAILS ABOUT THE PROJECT.
Teacher Notes
Step 1: THINGS REQUIRED.
1. A BC547 TRANSISTOR
2. 1KOHM RESISTOR
3. A BREADBOARD
4. LED
5. WIRES AND TOOLS LIKE WIRE CUTTER.
Step 2: THEORY OF THE PROJECT.
The normal (untouched) circuit is open and no current passes through it. When we will touch the two wires coming out from the transistor (one from the collector and another from base), the circuit gets complete and thus current flows making the LED to glow.
This happens due to the transistor. It has three pins. Collector, Base, and Emitter (as shown in the figure).When the two pins i.e. pin 1 and pin 2 are not touched, the circuit is closed but when we touch both the pins at the same time, the current passes through our body, making a path i.e. connecting pins 1,2&3 in series hence current flows through the transistor which gets out from collector to the negative of the LED and makes the circuit complete, glowing the LED.
Step 3: PROCEDURE
STEP-1: PLACE THE TRANSISTOR ON THE BREADBOARD AND CONNECT TWO WIRES FROM THE COLLECTOR AND BASE PINS RESPECTIVELY.
STEP-2: CONNECT THE EMITTER PIN OF THE TRANSISTOR WITH THE NEGATIVE RAIL OF THE BREADBOARD.
STEP-3: CONNECT A 1K-OHM RESISTOR WITH SERIES TO THE COLLECTOR PIN.
STEP-4: CONNECT THE NEGATIVE TERMINAL OF THE LED WITH THE RESISTOR AND THE POSITIVE TERMINAL WITH THE POSITIVE RAIL OF THE BREADBOARD.
STEP-5: CONNECT THE POSITIVE AND NEGATIVE TERMINAL OF THE BATTERY (POWER SOURCE) TO THE POSITIVE AND NEGATIVE RAIL OF THE BREADBOARD AS SHOWN IN THE VIDEO.
FOR MORE DETAILED INFORMATION, PLEASE WATCH THE VIDEO AND THE DIAGRAM ATTACHED.
Step 4: RESULT.
WHEN WE WILL TOUCH BOTH THE NAKED WIRES FROM COLLECTOR AND BASE PINS OF THE TRANSISTOR, THE LED BULB GLOWS.
YOUR TOUCH SWITCH IS READY.
For more, visit our website- www.piysocial.weebly.com and also to our youtube channel- https://www.youtube.com/channel/UCfm9shNVw-sBYgpFp...
THANK YOU!
Be the First to Share
    • Arduino Contest 2020
    • First Time Author Contest
    • Space Challenge
      Space Challenge
    2 Discussions
    Ranjanrishu7091
    Ranjanrishu7091
    Question 1 year ago
    What are it's applications
    SaswatSamal
    SaswatSamal
    Answer 1 year ago
    I'll be posting another video about it's application. Keep Waiting For that.:)
