TRIPLE CNC MACHINE - UPGRADE
549
14
Introduction: TRIPLE CNC MACHINE - UPGRADE
About: Tecnical Teacher
Hi Makers,
After a few weeks' break, we are back with a new project. In this video, we will try to make a simple cnc machine with you. “ A SIMPLE HOMEMADE TRIPLE CNC MACHINE “. Yes you heard right. We have done this before :) Lİnk is Here : TRIPLE CNC MACHINE .
But this time we have improved our machine. We upgraded. And there is a wonderful surprise for you in this CNC machine. we've used a system you've never seen anywhere. Spindel motor or a dremel was always used on Youtube and different platforms. You are aware of this.
In this project we used a "BRUSHLESS MOTOR" or "DRONE MOTOR". Yeah, you didn't hear it wrong.
Simple Homemade Triple CNC Machine has 3 features with this function. With this cnc machine you will be able to do 3 different jobs.
-Engraving with Brushless Motor as a Router,
-Laser cutting and drawing
-Drawing with pen as a Plotter.
Our project consists of 3 videos. In our first 2 videos you will see the construction of our cnc machine. Our third video will be a wide test video.
With the new drawings that we designed as a plug-in, it will be quite simple to use cnc. All you have to do is remove the parts we share in the video description from your 3d printer and provide the necessary materials. Our design is quite simple. No unnecessary material. No unnecessary wires. our design is quite simple. In our video, we tried to show how to do our cnc machine in the finest detail. We went step by step.
Teacher Notes
Step 1: What We Need ?
Hi Again,
If you have decided to build a TRIPLE CNC MACHINE, you are right place. But to build, you will need some equipments and materials. So, ask is coming for you. What we need ?
We have divided the materials we need into 3 groups.
1 - Mechanical Parts
2 - 3D Printable Parts
3 - Electronic Parts
Lets see them...
Step 2: Mechanical Parts
As you can see in pictures, we need some mechanical materials. And you can find detail list in below
=GIJON TIJS & LINEAR SHAFTS=
Chromed Linear rail roud rod 500 mm * 4
Chromed Linear rail roud rod 400 mm * 2
Chromed Linear rail roud rod 100 mm * 2
Trapezoidal T12mm Lead Screw 400 mm * 1
Trapezoidal T12mm Lead Screw 100 mm * 1
Trapezoidal T8mm Lead Screw 500 mm * 2
Trapezoidal T8mm Lead Screw 400 mm * 1
= NUTS =
M3 , M4, M5 M8, M10
= RULMANS=
LM8UU LINEAR BEARING * 16
608ZZ BEARING * 4
STEPPER MOTOR COUPLER ENCODER * 2
COUPLINGS 5mm to 8 mm * 4
= SCREW & BOLT=
M6 , M4, M3
= WOODS =
Wood 1 Dimentions : 500x700 mm X 1
Wood 2 Dimentions : 300x400 mm X 1
Step 3: 3D Printable Parts
We designed some 3d parts. They were drawn on solidworks. And printed with Prusa i3 3D Printer. We added on last steps STL files for your printer. You can find them there.
Step 4: Electronic Parts
And last materials are about electronic.
- Arduino Uno * 1
- Nema 17 Stepper Motor * 5
- Blue laser module laser engraving and cutting TTL module * 1
- V3 Engraver Shield 3D Printer CNC for arduino CNC Shield * 1
- A4988 motor driver * 3
- BDX53 * 1
- 100 OHM resistor * 1
- Fan
- 12 V 30 A DC Power Supply
Step 5: Let's Start Project
Firstly we will built first floor. We cut out woods with huge CNC machine. We need some materials in pictures. We plug 3d wood parts on wood table. Put shaft and tijs to hole on parts. You can see on pic "how?" or watch our video tutorials.
timeline is 02:47
Step 6: Assemply Main Header
We are assembling main heaser for laser, pen and brushless motor.
timeline is 07:26
Step 7: Assemble Header and Main Wood
As you can see in pics, we designed very simple and usefull cnc. Plug and play :D
How to built ? Check pics or video tutorial Timeline is 11:45
Step 8: Assemble Electronic Parts
and we are going to finish. A little bit more patience :D All connections will be add last steps.
Tutorial timeline is 01:23
Step 9: Second Floor
second floor coming...
Step 10: Assembly Holders
Very simple. You can assemble them speedly. Check it timeline is 10:00
Step 11: ShowRoom
Step 12: And FINAL...
Step 13: FILES...
All 3d printer STL files: https://www.thingiverse.com/thing:3974668
Electronic Circuit - http://bit.ly/2vbjTu0
Xloader - http://bit.ly/2IMpCyC
Hex Files for Arduino - http://bit.ly/2IMpCyC
LaserGRBL - http://bit.ly/2IMpCyC
How to upload code ? ( in Version 1) : http://bit.ly/2IMpCyC
How to calibration ? ( in Version 1) : http://bit.ly/2IMpCyC
How to add a pic ? ( in Version 1) : http://bit.ly/2IMpCyC
THANKS FOR PATIENCE - TO BETTER WORLD
Robotics Contest
Robotics Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Lorage_17
    Lorage_17
    Question 23 days ago
    Hello this is a great project that I
    have wanted to do for a long time and I finally started buying components
    unfortunately there are two things that I do not understand in your list. The
    first is that I do not understand very well the difference between the STEPPER MOTOR COUPLER ENCODER and the COUPLINGS
    5mm to 8 mm. In fact I do not clearly understand what the photos
    correspond to. And my second problem is that you do not specify the pitch and
    other information for the Trapezoidal T12.
    For example I do not know which Trapezoidal T12
    I should choose on the aliexpress site. Thank you in advance for your
    response and your help.
    https://fr.aliexpress.com/item/33019154008.html?spm=a2g0o.productlist.0.0.40d11534RhxNBy&algo_pvid=5ef25532-0ef5-4d42-9c18-c288196d4042&algo_expid=5ef25532-0ef5-4d42-9c18-c288196d4042-37&btsid=bfecadc7-f8e5-403d-b123-36ebe1dffb4c&ws_ab_test=searchweb0_0,searchweb201602_2,searchweb201603_53
    https://fr.aliexpress.com/item/32507277503.html?spm=a2g0o.detail.0.0.d1466b6cCfgGdp&gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=b22faffb-d9e8-4f23-864b-c6a8b92d26fe
    huseyinsevgen
    huseyinsevgen
    5 weeks ago on Step 10
    merhaba kalem aparatının 3d dosyaları eksik sanırım tamamlarsanız sevinirim iyi çalışmalar
