TTGO T-Watch Robot
About: Make it yourself if you cannot buy one!
This instructables shows how to turn a TTGO T-Watch to a tiny robot.
Teacher Notes
Step 1: Preparation
Step 2: 3D Printing
Download and print the chassis at thingiverse:
https://www.thingiverse.com/thing:3801194
Step 3: Install Rubber Rings
Install 7 mm rubber ring on the 3D printed wheels.
Step 4: Install Wheels
Install wheels to the tiny motors.
Step 5: Install Chassis
Install nylon balls and motors to the 3D printed chassis.
Step 6: Soldering Work
Here are the connection summary:
Motor Drive Board
IN1  -> Motor 1 pin A
IN2  -> Motor 1 pin B
Vcc  -> T-Watch VDD3V3
GND  -> T-Watch GND
IN3  -> Motor 2 pin A
IN4  -> Motor 2 pin B
EEP  -> Vcc
OUT1 -> T-Watch pin 13
OUT2 -> T-Watch pin 14
OUT3 -> T-Watch pin 25
OUT4 -> T-Watch pin 26
Note: T-Watch pin 13 and 14 require soldering on FPC socket.
Step 7: Assembly
Put the T-Watch on the chassis and screw up 14 mm M2 screws.
Step 8: Adjustment
The 8 mm nylon ball may not align with the wheel at the same level. Enlarge the chassis upper hole can adjust the level.
Step 9: Program
Step 10: Enjoy!
It's time to add your custom code to your tiny robot!
Step 11: What's Next?
Soldering the pins on FPC socket is not easy. TTGO is designing a motor board for building robot, hope this can release soon.
Make it Move
Make it Move
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
