TV Remote Repair
Introduction: TV Remote Repair
About: "Nobody could make a greater mistake, than he who did nothing because he could only do a little" .... Edmund Burke ahimsa Med-legal consulting and teaching to keep the brain juicy and animal ...
A while back my TV was turning itself on and off. Cutting to the chase, I discovered it was my TV remote control when the problem ended when the batteries were removed.......so...how to fix it.
Step 1: Open the Remote
I opened the remote and noticed there was an "oil" on the rubber key pad and circuit board.
Step 2: Swab the Parts
I took a swab dampened with alcohol, and cleaned the "oil" off.
Besure to get into the recesses on the rubber pad.
I reassembled the remote and it worked perfectly!
This has also worked for my cordless phone keypad.
Fix It! Contest
Fix It! Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    2 Discussions
    michaelb2
    michaelb2
    1 year ago
    From my understanding, the "grease" is impregnated into the rubber to make it conduct. When it stays on the circuit board, it shorts it out.
    JohnW51
    JohnW51
    1 year ago on Step 2
    Hmm. I think the grease is actually supposed to be in there. It's probably a conductive grease that helps with the electrical conduction of the buttons against the circuit board pads. How would grease get inside your remote? The problem you had was probably due to some other contamination inside the case of the remote, perhaps moisture or dust or both. Anyway, since your remote is working now, the the fix worked. I have several old remotes lying around (don't know why, but can't bring myself to toss them out). I'v going to take one or more of them apart and see if they have grease in them.
