Table Centerpiece
2,529
66
6
About: I love to build DIY wood projects.
I love how this table centerpiece turned out. This flower center piece is designed for bottles that are 7 1/2" tall. We bought Fever-Tree premium ginger ale drink and used the empty bottles for this project. I burned the wood using propane torch to give it that texture look and than stained it with Minwax gray color.
Visit our website for more cool projects TheDIYPlan
Supplies:
• 1x4x8' (x1)
Wood Glue
Finish Nails
Tools for this project
Drill
Miter Saw
Tape Measure
Pipe Clamps
Table Saw
Nyalox Flap Brushes
Propane Torch
Milwaukee 1 1/4" Hole Saw Bit
Note: Lumber dimensions are listed as nominal size. See lumber sizes for actual dimensions vs nominal.
Disclosure: Some of the links on this page as well as links in “tools for this project” and “material list” sections are affiliate links.
Teacher Notes
Step 1: Burning Wood With Torch
Take 1x4 board and using the Propane Torch burn the wood until its completely black. Once the wood in burned on both sides, take Drill with Nyalox Flap Brushe and take off the burnt top layer. If you prefer the wood to look lighter than brush more layers.
Step 2: Cutting Boards
Now cut the boards at 45 degrees to provided dimensions in the cut list. Also, cut a board that's 22 1/2" long and rip it at 45 degrees so that bottom is 3" wide. This board is for the bottles to sit on.
Step 3: Drilling Holes
Take the top board and using Milwaukee 1 1/4" hole saw bit, drill 7 holes 3" apart.
Step 4: Staining
Using Minwax classic gray 271 stain the boards on all sides and wipe it off with a clean cloth.
Step 5: Assembling Everything Together
Once everything is stained, place the boards on a flat surface (may use claps to hold it together) and attach it using Wood Glue and Nail Gun.
Step 6: Insert Bottles and Flowers
Take the Fever-Tree premium ginger ale drink and insert the empty bottles for flowers. These bottles are 7 1/2" tall. You're done
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
    6 Discussions
    Van57
    17 days ago
    Amazing idea.
    Thank you
    M3G
    5 weeks ago
    Great work!
    WeTeachThemSTEM
    5 weeks ago
    It's beautiful! I love the finish and the way the recycled bottles fit and almost seem to float in the center. :)
