Table That Can Be Turned Into a Chair and a Storage Unit
4,445
112
12
Introduction: Table That Can Be Turned Into a Chair and a Storage Unit
About: Product Designer, Based in National Institute of Design, Ahmedabad
This is a classroom project where I made the furniture out of a plywood, mostly collected from the scrap and left over pieces found in the Wood workshop. I designed two different storage units that can be used together or individually.
This furniture can be completed in a day or two with simple materials.
Here, I would like to thank all the staff members starting from the wood till the paint workshop and also my guide who guided me through the entire process of making.
Step 1: Materials and Tools
List of Materials:
  • Plywood 15mm
  • Buffer
  • Sandpaper
List of Tools:
  • Panel saw machine
  • Nail
  • Hammer
  • Sander
  • Router
  • Drill machine
  • Planner
  • Stapler
  • Circular saw
  • Zigzag pin
Note: In case you don't have a sander, just use a file or sandpaper.
Step 2: Cut Frame Materials to Specific Sizes (Straight Cuts)
Draw the above mentioned dimensions on plywood board.
All dimensions in cm
You need four triangular pieces for making table top and base.
  • Cut two square pieces of 92 X 92 and cut it diagonally, hence you get four separate pieces.
  • Cut four more pieces of 50.80 X 46.75 with an ergonomic groove of 11.47 X 5.08 at one of its side.
  • Lastly cut four more pieces of 50.80 X 46.75.
Step 3: Getting the Pieces Cut
Two plywoods were joined end to end to by using stapler and later hammered using zigzag pins to hold together (I had to join them as I couldn't find big spare piece of plywood for making the table top and base).
Later the pieces were cut diagonally into two parts from one unit. Here I have used the Circular saw to cut the pieces.
The other square pieces were cut using Panel saw machine.
Step 4: Ergonomic Groove Handle
Cut out a filleted rectangle (11.47 X 5.08 cm) from the plywood board using a router machine or jigsaw.
But before cutting the piece out from the plywood, just make sure to drill a hole suitable enough so that the teeth of the router machine or jigsaw you are using gets through and through.
Later you can use flat and half round file to finish the edges and surface of the handle groove.
Step 5: Planning and Joining the Pieces
The edges and roughness of the plywood are smoothened using a planer machine.
Using hammer and nails, the plywood planks are joint end to end 90°.
Step 6: Sanding and Removing Particles Before Applying Primer
Using a hand held sander machine clean the entire surface to get it smooth.
Fill the broken, dents or gaps on the any of the surface using putty and later scrap it off when gets dried.
Step 7: Application of Primer and Paint
The product is almost half a way to reach its final look!
Get it first coated with primer. Once application of primer is done, sand the whole surface slightly using sand paper (Make sure not to remove the entire coat of primer, therefore sand it gently!)
Once sanding is done, you can apply the paint.
Note: Here, on my furniture I have used water based paint to get the matte finish surface. I used the duo tone to show color interaction. Black matte on outer surface and Neon green on inner surface.
Water based paints dry faster than the oil based paints.
Step 8: Here We Go, Finished Multi Usability Table !
You can clearly see the color codes. The outer part is black and inner part as green.
Now, you can play around with the furniture and form different ways of creatively combinations. May be a chair, a step, a table , a storage....anything!
Step 9: Other Possible Combinations
The above shown images are the combinations one can play with depending on your space and needs.
These are only quick rendered images done on Keyshot. Actual product may differ...
Epilog X Contest
Epilog X Contest
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    12 Discussions
    Brian M V
    Brian M V
    1 year ago
    This is great!!
    charlessenf-gm
    charlessenf-gm
    1 year ago
    Elegant! Patent before IKEA sees it!
    Araisrang Brahma
    Araisrang Brahma
    Reply 1 year ago
    Thank you very much
    Araisrang Brahma
    Araisrang Brahma
    Reply 1 year ago
    Thank you very much
    medanilevin
    medanilevin
    1 year ago
    Very cool, lovely idea!
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Those look like a lot of fun to make and use :)
    Araisrang Brahma
    Araisrang Brahma
    Reply 1 year ago
    Absolutely! It's fun to make and use them:)
    Araisrang Brahma
    Araisrang Brahma
    Reply 1 year ago
    Thank you very much
