Table for Table Saw
The first thing we did for this was measure the size of the preexisting table saw. Then we make a sketch of how big we wanted the table to be we chose one one thats 3 ft wide 5 feet long and 3 and 1/2 feet tall.
Supplies:
4, 12 ft 2x6
2, 8 ft 4x4
1 1/2 in thick 5x7
box of 3 inch screws
box of 2 inch screws
drop saw
drill
jigsaw
table saw
hand sander
Teacher Notes
Step 1: Building the Frame
We then started to cutting all the pieces we needed we started off with the legs which were 3 ft. then we started cutting the 2x6 and cut two 3 ft pieces and two 5 foot pieces. The we screwed together the pieces we had to make the basic frame. We also decided to add wheels to make it mobile and add and extra 6 inches to the table.
Step 2: The Table Top
The we cut the piece of 1/2 inch plywood to fit the size of are table which was 5 ft by 3 ft the we had to cut out a 26 in by 24 in hole on the end for the table saw and cut notches for the metal sled to slide out.
Step 3: Supports
We Then added a few support beams to strength it which were 2x4 to make it stronger so it wouldn't wobble. The we added little strips on each corner to make it shake less when you cut wood.
Step 4: Fitting the Table Saw
After we added supports we started making the adjustments for the table saw to fit better. First we made a big enough for the saw to fit in which was about a 2 ft by 2 ft hole. Then we added 3, 3 ft 2x6 and 1, 3 ft 2x4 to make a base for the saw to stand on. Then we added 4, 6 inch 4x4 to hold the table saw at the perfect height with the piece of plywood so we don't get any weird cuts when running a board across it. Before we finally set it in permanently we decided to sand it how to clean it up a bit to make it look a little better.
Step 5: Final Product
This is what it looked like when were finished with it this took about 3 weeks in class to build.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • CNC Contest
      CNC Contest
