Introduction: Temperature Measurement Using Esp32 and Thingsio.ai Platform
In this tutorial I am going to explain about measuring the temperature in the surroundings by using inbuilt temperature sensor present in esp32 development board. esp32 has many inbuilt sensors like the hall sensor used as the proximity sensor,touch sensor,temperature sensor. In this tutorial we are going to discuss about the temperature sensor.
Step 1: COMPONENTS:
Hardware :
1.esp32 development board
Software:
1.Arduino IDE
2.Thingsio.ai
Step 2: BLOCK DIAGRAM REPRESENTATION OF Esp32
Step 3: CODING:
#include <WiFi.h>
#include <WiFiMulti,h>
#include <WiFiClientSecure.h>
#include <time.h>
#include <sys/time.h>
#ifdef __cplusplus
extern "C" {
#endif
uint8_t temprature_sens_read();
//uint8_t g_phyFuns;
#ifdef __cplusplus
#endif
int count=0,i,m,j,k;
int t,t1,t2,t3;
int outputpin= A0;//ds18b20
//////////////////////////////////////// ALL DECLARATIONS for CLOUD //////////////////////////////
const char* host = "api.thingsai.io"; // OR host = devapi2.thethingscloud.com
const char* post_url = "/devices/deviceData"; // OR /api/v2/thingscloud2/_table/data_ac
const char* time_server = "baas.thethingscloud.com"; //this is to convert timestamp
const int httpPort = 80;
const int httpsPort = 443;
const char* server = "api.thingsai.io"; // Server URL
char timestamp[10];
WiFiMulti WiFiMulti;
// Use WiFiClient class to create TCP connections
WiFiClient client;
/////////////////////////////////////// TIMESTAMP CALCULATION function///////////////////////////////////////
int GiveMeTimestamp()
unsigned long timeout = millis();
// WiFiClient client;
while (client.available() == 0)
if (millis() - timeout > 50000)
client.stop();
return 0;
while (client.available())
String line = client.readStringUntil('\r'); //indexOf() is a funtion to search for smthng , it returns -1 if not found
int pos = line.indexOf("\"timestamp\""); //search for "\"timestamp\"" from beginning of response got and copy all data after that , it'll be your timestamp
if (pos >= 0)
int j = 0;
for(j=0;j<10;j++)
timestamp[j] = line[pos + 12 + j];
void setup()
Serial.begin(115200);
delay(10);
tzset();
// We start by connecting to a WiFi network
WiFiMulti.addAP("dlink_DWR-113", "madhukar66");
Serial.println();
Serial.println();
Serial.print("Wait for WiFi... ");
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
delay(500);
uint8_t temp_farenheit;
float temp_celsius;
char strftime_buf[64];
time_t now = 0;
struct tm timeinfo;
char buf[256];
void loop()
// int analogValue = analogRead(outputpin);
/////////////////////////////////////// SEND THE QUERY AND RECEIVE THE RESPONSE///////////////////////
// t1=(analogValue/1024.0) *5000;
// Serial.print("temp: ");
// Serial.println(t1);
/ t2=(t1/10);
// Serial.print("celc: ");
// Serial.println(t2);
/ t3=((t2 * 9)/5 + 32);
// Serial.print("fhrn: ");
// Serial.println(t3); //break;
localtime_r(&now, &timeinfo);
strftime(strftime_buf, sizeof(strftime_buf), "%c", &timeinfo);
sprintf(buf,"scan start %02d:%02d:%02d ",timeinfo.tm_hour,timeinfo.tm_min,timeinfo.tm_sec);
Serial.print (buf);
temp_farenheit= temprature_sens_read();
temp_celsius = ( temp_farenheit - 32 ) / 1.8;
Serial.print("Temp onBoard ");
Serial.print(temp_farenheit);
Serial.print("°F ");
Serial.print(temp_celsius);
Serial.println("°C");
delay(1000);
now++;
Serial.print("connecting to ");
Serial.println(host); //defined upside :- host = devapi2.thethingscloud.com or 139.59.26.117
///////////////////////////////////// TIMESTAMP CODE SNIPPET /////////////////////////
Serial.println("inside get timestamp\n");
if (!client.connect(time_server, httpPort))
return; //*-*-*-*-*-*-*-*-*-*
client.println("GET /api/timestamp HTTP/1.1"); //Whats this part doing, i didnt get
client.println("Host: baas.thethingscloud.com");
client.println("Cache-Control: no-cache");
client.println("Postman-Token: ea3c18c6-09ba-d049-ccf3-369a22a284b8");
client.println();
GiveMeTimestamp(); //it'll call the function which will get the timestamp response from the server
Serial.println("timestamp receieved");
Serial.println(timestamp);
Serial.println("inside ThingsCloudPost");
String PostValue = "{\"device_id\": 61121695920, \"slave_id\": 2";
PostValue = PostValue + ",\"dts\":" +timestamp;
PostValue = PostValue +",\"data\":{\"TEMP\":" + temp_farenheit +"}"+"}";
Serial.println(PostValue);
/* create an instance of WiFiClientSecure */
WiFiClientSecure client;
Serial.println("Connect to server via port 443");
if (!client.connect(server, 443)){
Serial.println("Connection failed!");
} else {
Serial.println("Connected to server!");
/* create HTTP request */
client.println("POST /devices/deviceData HTTP/1.1");
client.println("Host: api.thingsai.io");
//client.println("Connection: close");
client.println("Content-Type: application/json");
client.println("cache-control: no-cache");
client.println("Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.IjVhMzBkZDFkN2QwYjNhNGQzODkwYzQ4OSI.kaY6OMj5cYlWNqC2PNTkXs9PKy6_m9tdW5AG7ajfVlY");
client.print("Content-Length: ");
client.println(PostValue.length());
client.println();
client.println(PostValue);
//////////////////////////////////POSTING the data on to the cloud is done and now get the response form cloud server//////////////////
Serial.print("Waiting for response ");
while (!client.available()){
delay(50); //
Serial.print(".");
/* if data is available then receive and print to Terminal */
while (client.available()) {
char c = client.read();
Serial.write(c);
/* if the server disconnected, stop the client */
if (!client.connected()) {
Serial.println();
Serial.println("Server disconnected");
client.stop();
Serial.println("////////////////////// THE END /////////////////////");
delay(3000);
Step 4: OUTPUT:
Here's the output of values of temperature read from the sensor.
Step 5: GRAPHS:
The graphical representation of the values read from the onboard temperature sensor.
