The 10 GREATEST Plumbing Tricks EVER!
20,828
83
11
Introduction: The 10 GREATEST Plumbing Tricks EVER!
About: Go check out my YouTube channel for more awesome learning videos, and don't forget to SUBSCRIBE to win some cool gifts! WWW.YOUTUBE.COM/GOT2LEARN
Here's a compilation of cool DIY tricks I've learned throughout the years on the job as a plumber apprentice.
Step 1: NO ACCESS
Alright so if you’ve ever been stuck trying to find a way to cut a plastic pipe with no access, here’s a sweet trick that’ll help you out. Snag yourself some masonry cord, wrap it around your pipe and use a sawing motion to cut thru it, who knew you’d be flossing on the job...!
Step 2: TOOL-MADE SHELF
If ever you work in tight spots and don’t have a shelf to free up a hand? Grab your torpedo level and make one, now you could hang a screwdriver or store some driver bits on it and you’re sure not to drop them!
Step 3: TRANSPORTING SHEET GOODS
As a plumber, carrying sheet goods is a possible thing in a day, here’s a neat way to do it effortlessly. Get any size pipe wrench and clinch it on tight to serve as a grip, they always said it, work smarter, not harder!
Step 4: PIPE CUTTER SECRET
You were cutting a copper pipe and your cutting wheel snapped, that’s a bummer. Most pipe cutters have a spare cutting wheel in the knob, bet you didn’t know that one!
Step 5: PIPE WRENCH EXTENSIONS
If your pipe wrenches aren’t cutting it and you need longer ones but don’t have any, cut yourself 2 sections of some plastic pipe and use them as levers to aid you in the process.
Step 6: SAWZALL HACK
A reciprocating saw is a must on the job site but if for whatever reason you can’t find a blade for it, you can alternatively use a hacksaw blade to get you out the pit. Just make sure to start off nice and slow!
Step 7: NO DRIPPING
Are you tired of this? Lemme show you an easy fix. Just when you’re about ready to apply your solder, wipe off all the excess flux and proceed to soldering, this will inhibit any dripping that might normally occur on vertical joints.
Step 8: UN-KINK a PEX LINE
If for whatever reason you kinked a PEX line, here’s a cool little trick that’ll set you apart from the others. Get your plumber’s torch and heat up the kink, the plastic will slowly turn clear and take back its original shape!
Step 9: SHARKBITE REMOVAL TOOL
Sharkbite fittings can be difficult to remove without the proper tool, here are two alternatives that work surprisingly well. Either use an adjustable wrench, adjust to pipe size and pull or use an appropriate size talon to get that sucker off.
Step 10: COPPER PIPE SOCKET
If ever you need to tighten a nut but don’t have a ratchet extension, I gotcha…Grab some type M copper that has a long enough reach and hit the nut as straight as you can just like this, it’ll take its shape and you’ll be able to use it to in your hard to reach area.
Water Contest
Water Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    11 Discussions
    desertwalker
    desertwalker
    1 year ago
    Many Thanks for the tips. I have a handyman business and any tricks are useful. Good work.
    ShannonW49
    ShannonW49
    2 years ago
    Good collection of tips. I don't know how many times I've busted my knuckles trying to cut something (not just plumbing) in a confined place (#1) or been about ready to take a hammer to project with a bolt in a narrow gap (#10).
    JulioC150
    JulioC150
    Reply 2 years ago
    Great to hear! #10 is most useful when installing unistrut, I've used it several times and works great, only works with type M copper ;)
    TJLee089
    TJLee089
    2 years ago
    A short, to the point, video. Nice!
    JulioC150
    JulioC150
    Reply 2 years ago
    Thank you, that's how I like making my videos ;)
    Pa1963
    Pa1963
    2 years ago
    #4-A big c-clamp will do the same thing if you don't have pipe wrench handy.
    JulioC150
    JulioC150
    Reply 2 years ago
    Hey that's actually a good trick, i'll add it to my arsenal ;)
    marvelljones
    marvelljones
    2 years ago
    My favorite is #4. A lot of bladed tools have this feature, make sure you examine them carefully before you stop working and go to the store. Look up the brand/model on your phone if you have to, not stopping work for an extended period of time is well worth a quick web search.
    JulioC150
    JulioC150
    Reply 2 years ago
    It was to my surprise when my ex-plumber told me this, I found it very neat that they tought of that ;)
    Cool! The plywood handle is my favorite, I have to carry those all the time, and it's not easy to get the right grip.
    JulioC150
    JulioC150
    Reply 2 years ago
    Yes, that one to I really like, it's so much easier to transport sheet goods compared to doing it with your hands, have fun!
