The Big Dipper
This is a project that’s reformed from the original one, ” Arduino Fireflies ” What I did is that I only changed the time Led flashes , design of the board and the number of Led, the code and anything else is basically same from the original "Arduino Fireflies".
The pictures and what I actually wrote maybe a little different due to the reason that I decided to add another Led lightbulb to make a Big Dipper. ( At first I only wanted to make some stars in the night sky, but then I changed my mind and decided to do a Big Dipper which acquires 7 of them.) So the numbers of everything must be 7 to do so.
Supplies:
The supplies you need for this one are:
7 resistors
7 jumper wires
1 breadboard
1 USB cables
8 breadboard wires
7 LEDs (white)
Teacher Notes
Step 1: Step 1 Building the Circuit
Just do it as the picture shows , or you can go to "Arduino Fireflies" to see how it's done.
Step 2: Step 2. the Code
It is the same as the original -Arduino Fireflies-
But I changed the time it flashes ( from 3000 ms to 1000ms) and I added one more Led
https://create.arduino.cc/editor/JudyChiu/175ce5f9...
Step 3: Step 3. Decorating
In this part, I used a paperboard to poke 10 holes ( You can just do 7 ) and painted it using black, blue, and some white colors to create an image of the night sky and the sea.
Step 4: Step 4. Completing
Lastly, Just pop your led lightbulbs into the holes you poked through, and use some clay or tape to fix them. You’re done!!
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
