Introduction: "The Child" Ugly Holiday Sweater Aka: Baby Yoda-wear
So... "Baby Yoda" has taken the internet by storm and made his way into my heart. Disney's delay in marketing and merchandise has left me without a "Baby Yoda" Ugly Holiday sweater to add to my festive-wear arsenal. While this is my take on it, feel free to use what you have around, or go out and buy supplies. I mostly used what I had around the house spare a few pieces... and what little time I had in a very busy weekend (by the time I saw this contest). I know I am going to keep adding to this sweater, but I am submitting what I have so far... who knows, it might stay like this.
Supplies:
- Sweater
- Textiles & textile Tools:
- Fabric
- 2-sided fusible fabric interfacing (optional)
- Iron if you have fusible interfacing
- Scrap Ribbons & Trims
- Pompom
- Felt (or fabric, fleece)
- Polyfill stuffing (optional, I just cut up some fleece but more on that later)
- Fluffy Trim
- Needle, thread, and misc sewing supplies
- Wash-away fabric pen (or if you are like me, sharpies and an "I don't care, attitude"
- Painting:
- Fabric Paint OR Acrylic Paint & Textile Medium (paint)
- Brushes
- Paint tray (or a plate)
- ADX3d LED Lights, LilyPad, Conductive Thread kit
- Tools:
- Template
- Plastic (or plastic food containers/ scrap thin plastic)
- Cricut (or a good craft knife)
- Ruler
- Straight Edge
- Scrap paper
- Heat Gun
- Glue Gun
- E6000
- Accessories:
- "Doll" Eyes
- Bells
- Scrapbooking eyelets and eyelet setting kit/ tools
- Optional: More bells, sew-on rhinestones
Step 1: Make Your "Egg"
For the egg-shaped hoverer that The Child was seen in, I swapped in a present. I opted for a dimensional one, but you can do a single dimension. While I like the depth, I did notice that since I centered the main panel of the package, rather than the whole package (because doing it dimensionally was a second thought), that I did not have even spacing on either side of the package. If I were to do it again, I would even things out.
- Using a straight edge, make a square shape. I had a square box that I keep my thread in, I looked at it as a short cut and used it to create my square.
- Using your ruler, map out your angle for your dimension, and trace.
- If you are using a stiffer fabric, I would recommend removing one side of the interfacing's backing, laying it out on 2-sided fusible interfacing. This will hold a LOT better than hand stitching.
- Iron your fabric to your interfacing.
- Once firmly bonded, cut out the package and remove the other side of the interfacing.
- If you are using a stretchy or knit fabric, just cut out your pieces.
- Lay your pieces out on your sweater
- If you are like me and pulled a knit sweater out of your closet that you hardly wear because of snags in it, or whatever, carefully sew it to your sweater. I recommend doing small runs of stitches maybe 1cm long before an equally sized space. I was a bit lazy, so my sewing and spacing is a bit... more than that. This will allow your sewing to have stretch places, so you don't pop a stitch through wear.
- Keep sewing until your package fabric is secure.
- If you were thoughtful enough to have a sweater with less "give", use an iron to affix your package as per your interfacing's instructions.
Step 2: Paint "The Child"
- Find a reference photo for the pose you want. Even if you get started, as you can see from my painting, I clearly changed what perspective I wanted to use.
- Draw out your reference on paper (I used an envelope from junk mail!)
- Cut out to use as a template, then trace (with either a pen, sharpie like I did, or paint if you are feeling bold).
- Decide if you are using fabric paint or acrylic paint.
- If you are using Fabric Paint, decide if you are brushing or squirting it on. I would use a brush because otherwise, my work would look like a Jackson Pollock painting... I am terrible with fabric paint.
- If you are using Acrylic Paint, like I did, mix your paint to the color you want before mixing with your textile medium.
- Textile medium allows you to use the acrylic paint on fabric and have it be "wash safe". I used Ceramcoat Textile Medium this time, but you can use any brand. It claims it is for use with their paints, but I used whatever I already have and it has already passed a wash test. Use what you have if you can.
- Textile Medium mixed acrylic paint is heat set. It is recommended that you run it through a dryer. Because the fabric of my sweater is less than happy in anything but a dryer on low, I used my heat gun to set my paint. If you do happen to burn a hole through it as I did, you can easily use a yarn needle and some embroidery floss (or a bunch of layers of thread together) to sew it back up. Just use small zig-zagging stitches to mimic the knit pattern and no one will know).
- Paint your Child
- Paint your base layer. Allow to dry and repeat until it is well on.
- Then add your details
- I did the face first, then the inside of the ears, then the darker green for the outlining and wrinkles. I then did the mouth before using my finger to give a bit of color to his cheeks.
- Make sure that the area you marked for eyes is not too big or small by laying the eyes over it to check.
- Don't forget to give him a body. If I were to do it again, I would put more torso out of the box so that I can give him more robes.
- Paint the inside of the box. Think whatever your package's main color, but darker. Since my scrap fabric (from making some pajama pants last year) was mostly red, I went with a burgundy.
- After each layer, let it dry then heat set (or get impatient like I did, use the heat gun to dry and heat set it at the same time!).
- Don't forget the hands!
- Draw out vague hand shapes on some fabric (I had scrap fleece)
- Sew and then turn right side out.
- Stuff with polyfill (or cut up scrap fleece if you are like me).
- Sew shut and paint like the child.
Step 3: Decorate Your "Egg"
- Use your scrap ribbons or trims to add some flair to the package.
- I recommend measuring with plenty of extra... If you don't you will be short and have to add on a weird bow in a strange place to hide the fact you were an inch and a half short on the trim around the box edge. If you can, cut after you have sewn.
- If you have a wire-edged ribbon/trim, remove the wire if you can.
- Sew the trim on with the same tactics you sewed the package on (spacing and small areas of sewing).
- If the trim is easily frayed, you have some options to choose from.
- Melt the end with heat gun/ fire.
- Seal with hot glue (I did this because impatient. I covered it with puffy paint where visible).
- Sewing it/ wrapping with thread.
- If you would like to, you can use a glue gun, just remember, the dryer is not your friend then (but there is still value in line drying!).
Step 4: Clothe the Child
- If you are a smarter human that I am, you would have drawn out a template of more than just a head, that you can use to measure out the clothing. If not, you are like me! An "I'm winging it superhero!".
- Eyeball the shape of your clothing. If you would like, then draw a quick template, cut that out and check your measurements. Adjust for there. If you are feeling bold, reach right for the fabric you are using for his robes. I have brown felt left over from another project.
- Make the chest piece.
- Guess at some collar bits.
- Make tubes with cuffs for sleeves.
- Squish the hands into the tubes, scrunch up and sew to hide the stubs.
- Sew all pieces to the sweater.
- Dirty it up.
- I used some brown paint on my finger to smudge it up and give it character.
- I blasted it with my heat gun to set it, but turns out felt melts pretty quick, so I have some lovely holes and melty bits.
Step 5: Fix His Face and Make Him Festive
- Add the eyes.
- If you have the doll eyes, just poke em through, and put on the backing.
- If you have flat-backs, clue them on. Hot glue works, but I love E6000.
- Add a Hat
- Eyeball your basic hat shape
- Sew on some furry trim (I did it like you would sew anything else, outside to outside and turn it right-side out).
- Add a bell to the end.
- Clean up
- Remember when I mentioned a being short on trim while making the package? This is when I fixed that with a bow.
- Add some detail to the box by outlining the other dimensions.
Step 6: Create Templates to Make Painting Easier
If you are like me, this could get messy, so I created some SVG files to use as templates to make things easier.
- If you have a Cricut
- Create/ find SVG files
- I created the files using some clipart and this website: https://www.autotracer.org/
- Upload the SVG files to your Cricut
- Cut out the templates at your preferred size (I did some at 3 inches and some at 2.5 inches wide)
- at-at.svg
- black_and_white_fair_isle_christmas_sweater_print_.svg
- boba_fett.svg
- d55a0c4a3bdd5ccb78d19f1493403cd4_imgclipartfestcom.svg
- il_570xN.1129634658_tn7k.svg
- kisspng-snowflake-square-shape-line-snowflake-shap.svg
- mandalorian_skull.svg
- rebel-alliance-icon-0.svg
- stormtrooper helmet.svg
- tie fighter.svg
- untitled.svg
Step 7: Create Your Death Stars
- Using the templates, I painted on my Death Stars.
- Do it layer by layer, details last
- My Death Stars light up. Once dry, I began this long and arduous task.
- Poke Eyelets through where you want the light to shine through. Set using your eyelet setting tools.
- Unpack your LED light kit. It should have a battery holder, conductive thread, LEDs.
- SORT IT OUT! LAY IT OUT! Make sure + is with + and - is with - in the line.
- Sew your LEDs to the sweater to ensure they shine through the eyelet holes.
- Sew your circuit for the LEDs + to +, - to -.
- If you have never done it before, visit this website: https://learn.sparkfun.com/tutorials/lilypad-basics-e-sewing/all
- When sewing, I recommend testing at each light before continuing. This was my first light-up project like this, and I did not, and had to do a lot of un-doing.
- Remember to remove the battery when not in use!
Step 8: Add the Final Details
- Paint using the template-layer-detail method until your heart is content.
- Do the sleeves, do the back, do whatever your heart desires (my finishing touches will have to wait since I heard about this contest less than 72 hours ago... and it is currently 1:36 AM on a school night... and I have a first-period class).
- Add any other details you want.
- Add more bells & trim.
- Add sew-on rhinestones to make it look like you are blasting into hyperspace. Go wild!
Second Prize in the
Ugly Sweater Speed Challenge
