The Connection...
76
6
This project is based on the idea of 'dendritic' painting.
I saw a tutorial with this technique and I tried it.
(You can see the basic ideas here:
https://www.youtube.com/watch?time_continue=1&v=eerBW37SLxM)
Teacher Notes
Step 1: Materials
The materials used for this painting:
- a cardboard prepared for painting (~dim. 12.5 cm x 17.5 cm);
- a photo frame;
- two sheets of glass (~dim. 9 cm x 13 cm);
- a paper scotch tape;
- acrylic colors used on glass: gold satin, purple and silver.
Step 2: Creating the Dendrits
- On the first sheet of glass I put the three colors: gold satin, purple and silver
and I spread them a little bit.
- I pushed the second sheet of glass over the first one, with a small mismatch of the
edges. I pressed it firmly, spreading the colors.
- When I considered that the spread is sufficient, I separated the two glasses slow,
but trying not to slide them. On each sheet appeared the dendritic forms,
like in the image.
- Immediately, I pressed the cardboard over the one of the glasses with the hand
and after that I separated it. You can see the result in the last image.
I used on the cardboard a paper scotch tape to cover the laterals, in order to
guide somehow the image. After the image was created, the tape was removed.
Observations:
- Till the colors are still wet, more papers can be pressed over the sheets of glasses,
but each time the result is different and the colors are more pale.
- The separation of the sheets is a little bit difficult and this is the cause that a
mismatch of the edges is necessary. Eventually, if the sheets are thick, a sharp
object will be helpful to do this operation.
Step 3: Final Painting
- I waited to dry the colors 24 hours, just to be sure.
- After that, I used around the dendrits a glitter paste, with shiny effects,
some red accents from bottom to top and a new layer of shiny blue
in the top are. Like a sky!
After the colors dried, I put the painted cardboard in the frame.
Now, the "connection" is ready!
- I liked my dendritic experience. And the result is very random!
Paint Challenge
Paint Challenge
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    6 Discussions
    Suzana 1Penolopy Bulnick
    Reply 4 weeks ago
    Thank you, Penelopy and excuse the delay of the answer... :(
    I love this technique, even it's so random...
    All the best to you!
    Reply 5 weeks ago
    Thank you, Penolopy! It was a very nice experience!
    Have a nice day!
    Suzana 1Randomona
    Reply 5 weeks ago
    Yes! You are right! It's fun but in the same time difficult to decide
    what to do with the other papers! :)
    Thank you! Have a nice day!
    RandomonaSuzana 1
    Reply 5 weeks ago
    I can imagine :) Have a nice day too!
