The Internet Monster
Introduction: The Internet Monster
About: Hi, we’re Dane & Nicole, two makers that create stuff, which we happily share with you!
We are going to build a cute monster that repeats whatever the internet says, what can possibly go wrong?
Supplies:
Teacher Notes
Step 1: Project Video
Step 2: Body
The body of our monster is an old flower pot. It's best to take a plastic one to keep the weight low.
The rest is completely up to you, small or giant, anything goes.
Once happy with your choice, we drill a hole in the back. This makes sure that any wiring can leave the monster without showing too much.
Step 3: Mouth
With the body sorted out, it's time to make the mouth.The mouth will work like a lid, so we need to make one, and add a hinge.
You can make the lid with just about anything, in this case we've used some leftover wood. It's important that the lid is slightly bigger then the pot opening, so it can comfortably rest on the edges.
As a hinge we use this 3D printable one by RelixTay. A trip to the hardware will also do the trick.
The last thing to do is to attach the hinge to both the pot and the lid.
Step 4: Movement
To make our monster talk, we move our newly made lid up and down. A small servo is the prefect solution.
Attach it to the inside and we are almost done.
We just need to add a popsicle stick to the servo hub. You can saw it to the correct size and that concludes the movement step.
Step 5: Control
Now is the perfect time for a small test. To get started, here's a tutorial on setting up a Raspberry Pi.
First we attach the AIY Hat to the Raspberry Pi, after which we can attach the servo to the Hat.
You might have to solder some pins to extend the HAT, no worries there's a great tutorial.
Here's the python script the make our little pot friend flap violently:
import time<br>
# Servo setup
from gpiozero import Servo
mouthServo = Servo(24)
while True:
    mouthServo.min()<br>    time.sleep(0.2)
    mouthServo.mid()<br>    time.sleep(0.2)
Note, in this case the servo is attached to the servo 5 spot (see image)
Step 6: Decoration
The title promised a cute looking monster, and so far we only have a overly excited flowerpot.
Let's change that.
The plan is to give him two massive eyes and cover him in monster skin.
To make the eyes we take a see-through Christmas ball and spray paint the inside white. Adding black felt furniture pads gives us two adorable eyes.
Next up is the monster skin, we went to he nearest sewing store and spent some time looking for the perfect fit. We ended up buying a blueish fake fur. Now we can glue on this new outfit and add the eyes.
Voila, one cute monster!
Step 7: Internet Control
Now to the most questionable part of the project, connecting our hairy friend to the internet. We start by attaching a speaker, microphone and a Camera Module.
With the hardware taken care of, we move on to the software. Remo.tv makes it very easy to connect your creature to the internet. We do need to implement our own Text-To-Speech handler, the file to do this is attached.
And with that our project is complete. Anything that is sent to our monster via chat will enthusiastically be repeated.
Here's the link to our monster,let's hope the internet will behave...
Reuse Contest
Reuse Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    Montana4Marie
    Montana4Marie
    27 days ago
    Ha! Interesting.. 💜. Bet you’d know how to identify & REMOVE what I’m told may be a rasp ‘attacking’ (ie seemingly knowing my every text, etc.
    Sigh. Oh to have these sorts of skills..💜
