The Iron Giant | Head Build
8,927
91
10
Introduction: The Iron Giant | Head Build
Hi all :D
I recently saw one of my favorite animated movies again, with one of my favorite robots, The Iron Giant.
And I thought I could build the head of the robot remembering the last scene of the movie.
Below I will show you how I built it using basically an old fire extinguisher and basic tools.
Supplies:
Materials & tools
  • An old fire extinguisher
  • 2 Screws with nuts
  • A hacksaw and a coping saw
  • A dremel
  • Sandpaper
Step 1: Templates
Here I will leave the plans with the views of the head.
These plans are made for the extinguisher that I got, which has a diameter of 11.58cm. If you need in another measure, you can scale it.
Step 2: The Fire Extinguisher
I know that the robot in the film is made of iron (obviously) but the extinguisher that I was able to get was aluminum hehe. However, this material was perfect, because it is easy to work and also because it is thicker than steel, which gave it a better final shape.
As you can see in the picture, the extinguisher that I got is a bit conical, so I had to work on this.
First cut the nozzle, then with a hammer I gave it a dome shape, taking advantage to make the hole a little smaller.
Step 3: A Very Important Detail
To avoid inconveniences, I made in this step the famous head bump of the robot.
I used a metal sphere that I had at home, I drew the area according to the templates, a few hits withe the hammer and its ready.
Step 4: Base Part
First I cut the base part of the whole head of the robot, then I drew the cutting lines on its back and then cut using the coping saw.
Step 5: Cut the Jaw
As in the previous step, draw the next part on the extinguisher and cut it off.
Step 6: Give It Form
As you can see in the plans, the front part of the jaw is flat, so following those lines I made a slight cut so that later I bend the piece along these lines, and with the hammer flatten that area.
Also you have to flatten the part of the joints of the jaw, to give it the rounded shape
Step 7: The "mohawk"
For this part I made a cardboard template using the plans, then I tried it on the piece until it fit perfectly.
With this piece I drew the shape on the extinguisher and cut it out. Then I just had to flatten it.
Step 8: The Eyes Holes
Now draw the holes of the eyes and then cut them using the dremel.
With the dremel I first marked the outline of the eyes as deep as I could. Then I made two cuts in the shape of a cross, then pry and take out the pieces that I do not need.
Step 9: First Look
At this point this already remind me the robot of the movie.
Now it's time to remove all the paint. I tried using paint remover but it did not work, so I tried to burn the paint a bit and then sand it, the final finish seemed interesting to me, so I left it that way.
Step 10: Joining
Having ready the parts we can begin to join them, the "mohawk" I joined using epoxy, on the internet I read that tin can be used but I have not tried it, it sure is much better.
To join the jaw, put it in place and mark the points and then drill with the proper size, I did not get the allen screws so I used hexagonal head screws. If you want you can cover the hole in the head with more epoxy.
Step 11: More Details
At this point the head is already finished, but we can add a few more details. Trying to imitate more the robot of the film, I stuck a rubber ring that I found at home inside the holes of the eyes, and below that a sheet of translucent plastic. Improvisation! :D
If you want you can also add lights inside, they look great.
Step 12: Finished!
And that's it. So we transform an old fire extinguisher into a memory of a great movie.
I hope you liked it :)
Fandom Contest
Second Prize in the
Fandom Contest
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    10 Discussions
    erukajuminten99
    erukajuminten99
    1 year ago
    nice idea, recycle everything, make globe green again
    offseidjr
    offseidjr
    1 year ago
    Wow! Finished product looks amazing!
    bmohr
    bmohr
    1 year ago
    I really like this project. Nice way to turn trash into treasure.
    F_A_B_A_S
    F_A_B_A_S
    Reply 1 year ago
    Thanks!
    ChrisE168
    ChrisE168
    1 year ago on Step 12
    Great job! My kids love Iron Giant. Now if I can only find the time to make this.
    jmadara
    jmadara
    1 year ago
    Well done!
    WeTeachThemSTEM
    WeTeachThemSTEM
    1 year ago
    So cool! I love that you made this from an old fire extinguisher. :)
    F_A_B_A_S
    F_A_B_A_S
    Reply 1 year ago
    Camolution
    Camolution
    Question 1 year ago
    What kind of fire extinguisher did you use? This is great!
    F_A_B_A_S
    F_A_B_A_S
    Answer 1 year ago
    I got a 5Kg CO2 fire extinguisher, made of aluminum with a thickness aprox. 3mm
    It actually works with almost any type of fire extinguisher, you just have to adapt the dimensions.
