The LEGO Hopter
Introduction: The LEGO Hopter
Have you ever wanted a bright LEGO Plane in the dark? Well, then this is a pretty simple one to make.
Supplies:
  1. LEGO
  2. LED
Teacher Notes
Step 1: Step 1: Body of Airplane
  1. First, you get a 2x10 brick and put a TINY wheel on the front of the 2x10 brick.
  2. Second, you get a 2x1 brick with 2 holes on the side. Add 2 horns onto the side.
  3. Put a lever on the 2x1 brick that has 2 HOLES REMEMBER and has 2 horns.
  4. Then put it on the 2x10 brick.
  5. After, get a 4x12 brick and GET 2 OF THEM and put 6 slope bricks ON EACH SIDE: One on the right and one on the left. And put a chair seat lego behind the 2x1 brick.
Also look at all the photos. It will be easierfor you.
Step 2: Step 2: *Legs*
  1. Next, get a 2x8 flat brick and put it one space behind the wing of the plane. Also put it sideways.
  2. Then, put a 2x6 flat brick and put it on top of the 2x8 brick.
  3. Then, put a sword on the bottom.
  4. Afterwards, you get a 2x1 curved brick and get a Fake DC LEGO Gun 2 of them. Put them together and stick it. Then, get a fire LEGO then stick it on the 2x6 brick.
Step 3: Step 3: LED
  1. First, you put LED on the side of the wings and stick it with hot glue or tape. I would recommend hot glue.
  2. Then, do the same but on the back.
  3. It will light up in the dark but mine glowed.
Make it Glow Contest
This is an entry in the
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
