The Money Maker D I Y
Introduction: The Money Maker D I Y
About: SlavSurvivalist387 based in Balkans it is a project that will progress into tech from basic to pro like a true slav making our way from forging metals to making high tech machines
I this video I will show you the process of making forge nicknamed "The Money maker", it is named money maker because one of my friends said that machines and tools are the real money makers so it sounded cool. In the future we will use it for forging tools and knifes and there will also be a part 2 of this where I will make it "modern" using some sweet tech.If video is bad I'm sorry it is been a long time since I made a video and most of my material was lost and I was left only with some of the pictures, I hope next part will be better, stay tuned and subscribe for more videos and useful material.
Teacher Notes
Step 1: Cleaning
First thing in converting this old water heater in to furnace is cleaning, I used angle grinder, steel brush to clean it and make nice and clean for welding part.
Tools:
  • Angle grinder
  • Steel brush
  • Arc welder
  • Hamer
  • WD 40
  • Wrench
Parts:
  • Old water heater
  • Hinge
  • Metal pipes ( 30 cm long, or whatever you have)
  • 3x chamotte brick
  • Scrap meta
Step 2: Welding the Hinge and Handle
After I cleaned the tank I made one side cut, over which I welded a old door hinge, handle was made from two small pipes.
Pipes were welded in T shape, and on the other side of the tank.After putting hinge and handle, I cut tank so the 1/4 of the thank can be open.I did this so the furnace can be cleaned.
Step 3: Making Insulation
For insulation of the furnace I used chamotte brick's, because chamotte brick's are fire resistant.I used 2 whole bricks and one that I split in 4 pieces.
You can also use special glue to fix them, but I did not do that, because of future modification.
Next part will be more quality and better than this one, I use to have more material while writing but I lost 90% of video and pictures during the process, sorry if this is not best work you seen but I promise it will be more fun in next project.
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    2 Discussions
    tomatoskins
    tomatoskins
    1 year ago
    This is great! Sorry you lost so many images and video. How long did it take you to make?
    SlavSurvivalist387
    SlavSurvivalist387
    Reply 1 year ago
    My camera was bad and, I was only left with footage from the phone, not long, tnx for the advice and help
