The Plotti Botti: an Internet-Controlled Drawing Robot!
Introduction: The Plotti Botti: an Internet-Controlled Drawing Robot!
About: Hi, we’re Dane & Nicole, two makers that create stuff, which we happily share with you!
The Plotti Botti is an XY plotter attached to a whiteboard, which can be controlled by anyone via LetsRobot.tv.
Teacher Notes
Step 1: Overview
Below a quick overview of the content.
  • Introduction and showcase video
  • 3D-printed parts
  • Soldering
  • Stepper motors
  • Letsrobot.tv
  • Gondola and toothed belt
  • Attach it all
  • Enjoy!
  • Tutorials
Step 2: Introduction and Showcase Video
When it's online, you can find the Plotti Botti here.
It was made using stepper motors with pulleys, a toothed belt, a Raspberry Pi, the Adafruit Motor HAT, a Pi Camera, a number of 3D-printed parts and googly eyes.
Step 3: 3D-printed Parts
First of all, 3D print the brackets
to hold up the stepper motors in the corners of the whiteboard, and the gondola that will hold the whiteboard marker. If you don't have access to a 3D printer, the Instructables on how to make the XY Plotter for Arduino has some alternatives.
Step 4: Soldering
Next up is some soldering! Solder the Adafruit Motor HAT as explained in their tutorial.
We also need to make sure the wires of the stepper motors are long
enough to reach the Raspberry Pi from the corners of the whiteboard. If they're not long enough, solder on some longer wires.
Step 5: Stepper Motors
To power the Motor HAT and the
stepper motors, we're using one of the power adaptors recommended in the tutorial, as the XY plotter will be stationary. When the stepper motors are working, attach the pulleys to the end of the stepper motors, as seen in the Instructable.
Step 6: Letsrobot.tv
Create and connect your robot to LetsRobot.tv following their instructions.
This is all very straightforward, except for installing FFMPEG, as this didn't work. The fix that worked for us can be found on Hackster.
After the initial setup, adjust the code in controller.py to fit the needs of your robot.
Step 7: Gondola and Toothed Belt
Attach the toothed belt to the gondola and the weights, as demonstrated in the Instructable.
Step 8: Attach It All
Arrange the PiCamera in a way you can see the full whiteboard when
controlling it via LetsRobot.tv. We attached our PiCamera to a standing lamp.
Step 9: Enjoy!
Plug it in and enjoy other people controlling your robot from the comfort of their own home.
It's magical!
Step 10: Tutorials
IoT Challenge
IoT Challenge
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
