The Powerful Laser Pointer
The 3w laser pointer anodized aluminum manufacturing process is widely strength is very high, the halogen lamp life is about 2000 hours with adjustable mirrors and super heat-resistant lens, when the handle is not burned can also provide you switch between different exposure mode with different handle situations The most important question in the area of inflammation, such as matches or lighter than using the more simple. Since the brightness is too high, so the heat is quite high, after the cap was dazzling mirror collected immediately, instant piece ignite Papyrus grilled beef, if you wish, you can also use it for cooking eggs.Laser Pointer this tradition is no longer the traditional products through N years of evolution "Star Wars" Jedi inner perimeter now has more back and become similar to a lightsaber. Before the laser pen 303 may have seen a lot of light, including laser Laser Pointer functions.Lumen 5000 is what concept? Lumen is the unit of luminous intensity, standard incandescent bulbs only 340 lumens, a projector easy to assume, as a rule, only about 2000 lumens projector with one moment to the very hot as there is no fan, an estimated initial spontaneous combustion! In the cinema, the kind of professional digital projectors see only about 10,000 lumens. So the 5,000 lumen laser pointer 500mW, which has a real "killer"!
This movie gives a nice view on the basis of animation on the formation of a high power green laser beam. All the ingredients for a laser pen 10000mw buy are appointed in this movie. To make a laser, you need a large collection of atoms generate that energy. As soon as one of the atoms with a photon comes into contact, the other atoms are also stimulated with energy. Instead of letting escape all the energy, you can catch it between, as it were, two mirrors.Energy of a laser pen.If all of this energy is collected in one space, the space will be full of energy which continues to bounce off the walls. This energy causes light, which energy due to the more and more light will produce. This is because photons always wanted to be united. In contrast to a piece of money is thrown, which heads and tails may fall, it is for photons 'logical' to be the same.This allows for an infinite energy in a unified space. As soon as an opening is created in this space, the light rays will as a coherent beam to the exterior. This will then be visible as a laser pen Purple in a certain color.
laser 3000mw at specific wavelengths such as 473 nm mostly the same basic structure as DPSS green lasers. In 2006 began with many factories producing blue laser module for mass storage, and these were used in laser pointers as well. These were frequency doubled DPSS type devices. Most transmitting a beam at 473 nm, which is produced by frequency doubling of 946 nm laser light from a diode-pumped Nd: YAG or Nd: YVO4 crystal (Nd-doped crystals usually produce a principal wavelength of 1064 nm, but the good reflective coating mirrors can also be made to lase at other "higher harmonics" non-promoter neodymium wavelengths). For high output power BBO crystals are used as frequency doublers; for lower power KTP is used. The Japanese company Nichia controlled 80% of the blue laser diode market in 2006.Pressure switch at the bottom, no need to take into use when to hold it.The term laser stands for Light Amplification by Stimulated Emission of Radiation, which translated means light amplification by stimulated emission of radiation. By means of a physical effect to be generated artificially focused light beams, the term describes both the laser pointer 3000mW amplification effect and the radiation source and the light beam. Unlike conventional light sources such as incandescent laser beams are distinguished by special properties. These include the very narrow frequency range, so that the light has only one color. Moreover, the laser beam over long distances slightly larger and has a long coherence length. These characteristics are the reason that laser lamp starry be used in various fields. Thus, for example, laser cutting and welding, 20mW Green laser Pointer Pen scalpels in medicine, such as distance measurement devices, military technology or control technology.
Authentic aluminum ensures the sustainability of these 2000mW High Power Laser Pointer Attacked Head Blue Suit. This professional laser pointer is easy to operate. What's more, craftsmanship makes to keep it smooth. Just gently press the switch button; you will notice a strong beam of blue light emitting laser pen. With such a portable tool, you can point to a target as far as 5000 meters. It is suitable for many industries, such as tourism, wild exploration, mine stope etc. There is also two 1200mA battery, a case and a charger are included, which the laser pen is reusable and easy to carry. Above all, designed attacked head, may be appropriate to protect you as well. It really is a bargain. How can you refuse such an economic product?This project requires that your soldering experience and hopefully some knowledge of electronics. I would give this project a sophisticated valuation based on these things, but I think everyone can doen.Nu that you have read the warning and hopefully understand the dangers of high-powered laser we can continue.You can also buy the laser pen 303 on ebay or you can just pick your own from an old or broken DVD burner that you have laying around. And on the question you ask yourself to answer now, so it must have a DVD burner. Possible to 16x or higher speed. Normal DVD players diodes will not create a 500mw green laser with burning power. Not Never use a CD burner for this project. They contain infrared diodes. The light they emit is invisible to the naked eye and contain enough power to blind you before you even realize it's happening. Simply put, stay away from CD Burner diodes. You can not really see the laser it will anyway make.
    • Trash to Treasure
      Trash to Treasure
    • Remix Contest
      Remix Contest
    • Paper Contest
      Paper Contest
