Introduction: The Secret(ly Organized)-DVD-CD-#8 O-Ring, Holder-Hider-Compartment!
Reasoning:
before I did this I would lose track of my most useful cd. hiren
even in a colored cd case it spent days under newspapers.
I thought I would cut down a DVD case and glue pronged part near my monitor, I did not consider the dust when I cut the cases down to the nub, I might leave the lip, if I do this again.
Design considerations:
1 I just needed a special place to keep a boot-repair-test disk
I ended up making 2, (the one under the drawer is just for a contest.)you should figure out what you need or what will fit.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
2 DVD cases are more readily cut than the clear plastic cd cases
--test the release some hold some release some do neither
3 I recommend using double sided (foam) tape, but used the first glue I came upon. 4 measure: I kept the case and used it to verify that a cd would fit without hitting the edges. I guarantee 2 1/2" away and 5" apart is enough.
Organization Contest
Secret Doors and Compartments Contest
