The Shark
This is a skateboard looks like a shark.You can draw more attention when you skateboarding it on the street.Even the novices are easy to play.It's made of normal skateboard material.
Teacher Notes
Step 1: Make Bracket
Using some simple geometry to stretch and cut, they are combined into a complex structure of skateboard bracket, which is used to connect the wheel and the panel. The main body is triangular to enhance the stability.
Step 2: Make Panel
滑板被设计为指单跷跷板滑板。在面板上使用了水平面板,但是通过添加图案增加了摩擦。在面板形状的设计中,设计原型是一条鲨鱼。洁白的牙齿和红眼上的疤痕旨在使鲨鱼看起来更有力量。将鱼的尾巴改成滑板的凸起部分,以完成the。
Step 3: Make Wheels
In the aspect of wheel design, we refer to the wheel design of the Penny Board. The large and wide wheel enhances the stability of the skateboard when it moves. Although it reduces the operability of the skateboard, it can make the novice easy to start.
Step 4: Combination
用螺钉连接所有零件并匹配相应的颜色以完成滑板。
Step 5: Let's Enjoy It
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
