The Taco Phone Holder
8,204
61
23
Introduction: The Taco Phone Holder
About: Desktop Support Technician by day ... Occasional hired gun rock drummer by night ... DIY home improvement enthusiast on weekends - maker of whatever I can imagine in between it all. I'm also a professional l...
A lot of time, money, and design have gone into the creation and evolution of devices with the sole purpose of holding tacos in an upright orientation. I usually just sacrifice the weakest looking taco as the "dead solider," to support those whom remain - for the greater good. You know the one ... "private taco" with the cracked shell and cheese deficiency. You're dead to me private taco!!!
Perhaps this means I'm out of touch - or just a savage, somehow still existing in this modern era of taco cradledom. Surely, I have a bit of a defense due to the existence of the TACOsaurus Rex Taco Holder, which is a throwback to the late Cretaceous Period. Scientific data tells us that tacos were of course the snack of choice during that era, but I digress.
It's is my opinion that while taco holding may be an admirable cause, we need more instances of tacos doing the actual holding - it's about time they give back to society!
Ladies and gentlemen, children of all ages, fellow taco lovers ... the journey starts with smartphones ... a taco to hold a smartphone.
Step 1: Internal Box Fabrication
I started with the internal box, because it will establish the scale and therefore determine the dimensions of the taco shell. This is the cavity or pocket, which will hold the phone of smartness.
Since smartphones, nor case options, follow a universal standard of dimension, my measurements won't necessarily correlate if you decide to make your very own taco. However, I will cite them as a frame of reference, as well as list them all within the last step of the Instructable. This taco was built to hold an iPhone X with a somewhat bulky case and a "pop socket." It ended up being a pretty exact fit [Translation: I got lucky]. My iPhone 8 with a tech 21 fits with room to spare.
I used the drum sander to thickness and smooth two strips of poplar - one to 3/8" and one to 1/4". These strips were ripped to a width of 2 1/2" and cut to final size using my small parts crosscut sled on the table saw.
The 3/8" thick stock is for the front and back, which equals that of the future taco filling, while the 1/4" thick stock is used for the sides. It could all be done 3/8", which would be easier and quicker. The rabbets are also unnecessary, but I like to overcomplicate everything.
This box was glued up and clamped using painters tape.
Step 2: Shell Fabrication
Taco shell sides were my second target and I used a scrap of 5/4 poplar. I drew some layout lines representing the bottom plate and vertical center, so I could sketch some arcs and dial in a shape with which I was happy.
The block was cut down the middle on the tables saw and then the drum sander was used to remove tool marks, as well as reach a consistent 3/8" thickness.
A shallow (1/8" deepish) rabbet was cut into the bottom edge of each half. These accept the 1/2" thick bottom panel, which was cut to fit by sneaking up on the cut.
Step 3: Shell Shaping and Glueup
Shaping of the shell started by adhering the two sides together with double-sided carpet tape - insuring the rabbets were aligned (on the same side and facing each other). The arc was cut using the bandsaw and the shape finessed using the oscillating belt sander. I then decided to round over the sides of the internal box, but that turned out to be unnecessary.
Glueup was pretty simple and I was able to do it all at once. My only suggestion would be to let the glue tack up a few minutes before adding clamps. That way parts the parts won't slide around and causing frustration.
Step 4: Filling Fabrication
While the glue dried on the taco shell, it was time to make the filling.
Beef: Part of a runner from a reclaimed pallet - might be walnut, but I'm not sure. I jointed one face and one edge. Using the table saw, the board was cut into 3/8" strips. Those were then rotated and cut again to make square stock, which was then cut into 3/8" cubes using a small sled on the bandsaw.
Guacamole: The greenest poplar offcut I could find in the shop, which didn't need to be jointed, but followed the same process as the beef.
Tomatoes: A small scrap of padauk, which I ran through the drum sander for a consistent 1/4" thickness. Using the bandsaw and sled, it was cut into 3/8" wide strips and then 1/2" long sections.
Cheese: 3/32" thick poplar offcuts I had in the stop, which I carefully ripped into 1/8" wide strips. I then used the bandsaw and sled to cut 7/8" long pieces.
The most tedious part was sanding. It only took 3 quick swipes on each face, but each cube has 6 faces, so the time adds up.
Step 5: Taco Building
I considered two options for gluing all these little bits.
1. Superglue and tweezers, which I deemed to be way too tedious.
2. Coat them all in a thin layer of resin and pack them into the shell in one shot.
After sleeping on it, I decided that the resin option had too many possible points of failure, like pooling in the bottom, undesirable placements, a huge sticky mess, etc. I decided to move forward with the tedious, but controlled superglue option.
In reality, the process didn't take that much time - way quicker than the sanding in fact. I just used one drop of glue on one face and positioned the block with tweezers. I found that I could do one layer on one side and move to the other side while the glue set up. If I had activator/kicker, I wouldn't need to wait at all.
I filled the side pockets in with the beef cubes and started adding in the guacamole and tomato cubes towards the top. The cheese was last and I chose to go mostly with a vertical orientation - not only for visual height, but also to fill small voids while not obscuring pieces below. I had extra pieces, but I didn't want to overload the taco and end up distracting from the overall effect.
After assembly, I noted the taco wasn't sitting flat - it was rocking a bit. Using a sheet of sandpaper and the cast iron top of the table saw, I was able to quickly flatten the bottom.
Step 6: Taco Finishing
For finish, I started with a varnish from Total Boat, which I carefully brushed on in order to cover all of the small pieces. It left a bit more shine than I wanted, which looked fine on the filling, but weird on the shell. My solution was to sand back the shell faces and apply a few coats of satin spray lacquer.
Once the lacquer dried, I applied a coat of renaissance wax and buffed the shell.
Step 7: Taco Wrapping
The taco was a present for the warden, so I wanted to wrap it using a non-standard method. Rather serendipitously, I had a taco kit in the pantry - and the box was a perfect fit.
The foil wrap was for that shot of "bling." I added the second box just to add to the suspense and entertain myself.
Step 8: Glamour Shots
Looks like a taco and holds a smartphone - mission accomplished.
Doesn't taste like a taco - take my word for it.
The Warden loves it and people who witnessed it's debut liked it. She's taking it to her office for prominent display on her desk. Apparently misplacing the phone under stacks of paperwork is a real world struggle and the taco is the perfect solution.
So it's true ... everyone loves tacos and they solve all of your problems. I knew it!!
Dimensions
Taco Shell Front & Back: 3/8" thick x 3 7/8" width/height x 7" length [3/8" wide x 1/8" deep rabbets]
Taco Shell Bottom: 1/2" thick x 3 5/8" width x 7" length
Internal Box Front & Back: 3/8" thick x 2 1/2" width/height x 4 3/4" length [1/4" wide x 1/8" deep rabbets]
Internal Box Sides: 1/4" thick x 2 1/2" width/height x 1" length
Beef & Guacamole Cubes: 3/8" x 3/8" x 3/8"
Tomato Chunks: 3/8" x 1/4" x 1/2"
Cheese Shreds: 1/8" x 3/32" x 7/8"
Epilog X Contest
Epilog X Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Metalworking Contest
    23 Discussions
    Matt Makes
    Matt Makes
    1 year ago
    Wonderfully original, smart eye-catching design, and well documented. I tip my hat to you sir!
    tylerthecreator
    tylerthecreator
    1 year ago
    can i trade my litty like a titty fortnite account for this
    ManCrafting
    ManCrafting
    1 year ago on Step 5
    I voted for this. I know you want a laser. ;-)
    JeffE55
    JeffE55
    1 year ago
    I like it, really fun build. My only suggestion is to replace the guacamole with lettuce, I'm too cheap to pay the upcharge.
    marvelmx
    marvelmx
    1 year ago
    Interesting idea but that doesnt resemble a taco at all.
    -BALES-
    -BALES-
    Reply 1 year ago
    It's all good. The Remix contest is coming up, so feel free to make a version that meets your criteria for a taco.
    marvelmx
    marvelmx
    Reply 1 year ago
    A real taco has a completely different form. Is not hard or straight and could hold a phone this way. So this form is baffling.
    -BALES-
    -BALES-
    Reply 1 year ago
    You must be a real hoot a parties.
    Eh Lie Us!
    Eh Lie Us!
    Reply 1 year ago
    ok, guys. I think we're good here. Let's put them back in the holsters...
    one of the reason that I love this site is because it brings creative minds together. We share advice, which I suppose if it's unsolicited could be considered criticism. When i shared the post with my coworkers they knew immediately what it was and got a kick out of it. By a look at the comments, the vast majority love this taco and obviously the creator likes it to so - that's it. Great job done. Unplug the tools. Sweep up the shop.
    Now when I look at it, it looks like a MineCraft taco which takes it to a whole new level. -BALES- thanks for posting and sharing the inspiration. Personally, I'm looking for more creative ideas such as yours.
    Eh Lie Us!
    Eh Lie Us!
    Reply 1 year ago
    As the instructions suggest please be positive and constructive. That being said, my 1st take was similar to yours but I asked myself what would make it more taco-like. I think if the bottom looked more curved and less boxy. Also if the toppings were more colorful. The latter being difficult since the wood is a stain so you can't get TOO red or green. Overall a neat project.
    marvelmx
    marvelmx
    Reply 1 year ago
    To approach the color better, some stains could be added to simulate better a tortilla.
    The thing is I am mexican and I know what a taco is, therefore this form is baffling and I can not identify this shape as a taco. Tortillas and tacos are soft and floopy and dont bend like a paper binder
    -BALES-
    -BALES-
    Reply 1 year ago
    I'm Mid-Western and I don't like wood stain.
    Image result for square taco
    candyallis
    candyallis
    Reply 1 year ago
    As a frequent eater of tacos, I said to myself while scrolling through, "Is that an iPhone in a taco?" So I feel like it definetly looks like a taco...
    geeksmithing
    geeksmithing
    Reply 1 year ago
    Interesting comment but that doesn't resemble a positive or constructive post at all.
    Barry6470
    Barry6470
    1 year ago
    Brilliant build it's making me hungry now!!!
    Good Luck in the Comp, you got my vote.
    Barry (ENG)
    Love the taco idea.Don't eat your phone it won't taste as good as the wood.haha
    AwesomeWood
    AwesomeWood
    1 year ago
    Taco... for the win! :-D
    Lorddrake
    Lorddrake
    1 year ago
    Nice Work.
    now you need to make a mark II version .. it has a charging cord integrated into the design so it isn't just a holder .. it is a holder/charger
