The Winged Spear
Introduction: The Winged Spear
This spear will exist in a future game
P.S I didn't create this photo props to the original creator. The orginal post: https://twitter.com/0Silphium/status/1085428936199364614
Step 1: Attaching an Canvases
First, go ahead and find the image used.https://pbs.twimg.com/media/DxA32z2W0AAxXzk.jpg open this link in a new tab and save it as a png. After saving the file head over Fusion 360 and open a new project. Attach the picture as a canvas on the YZ plane by clicking Insert, attach canvas, then clicking on the YZ plane.
Step 2: Creating a Sketch
Using the canvas make sure that it is visible you can check by checking the browser if the canvases light bulb is on and the canvas image. Once the canvas is a visible click, sketch then, create a sketch. Start making an outline of the spear on the image, use the line and the spline tool or 3 point arch to create the sketch, you may also use other tools in the sketch if you wish. If you wish you can also make the parts different sketches, or add new parts if you wish, similar to me.
Step 3: Creating the 3d Model
Once finished do the sketch, click create than extrude click on the selectable sketch, you may make each different measurements or one. You may extrude the sketch to desire measurements or, following along with me extrude the sketch 5 mm.
Step 4: Adding Some Final Toches
Once done extruding start adding some Fillets and chambers to the edges of the model. mostly on the handle and the blade, you can also put some on any other creations done, make the fillets and/or chamber to your desired length depending on the area.
Step 5: Thanks for Reading
Thanks for reading this instructable, if you want some more tips you may ask, you can also tell me some tips for creating another instructable!
P.S I didn't create the image thanks to the original maker of the photo. https://twitter.com/0Silphium/status/1085428936199364614
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
