Thermoplastics Flowers
About: Solarbotics has been sharing electronics, kits, and BEAM Robotics with the Geek community for over 20 years! We carry Arduino, LEDs, electronic equipment, 3D filaments, printers and programmable components. ...
Today we are going to be taking a look at one of our favorite go-to materials for easy molding and quick repair, Caprolactone Thermoplastic! This plastic, more commonly known as ShapeLock, Friendly Plastic, Instamorph or Polymorph, is a biodegradable polyester with a low melting point. When solid, it has physical properties of a very tough, nylon-like plastic, but will melt into a putty-like consistency at only 60°C. Caprolactone's specific heat and conductivity are low enough to make handling a breeze and are ideal for small-scale modelling, parts fabrication, repair of plastic objects, or rapid prototyping where heat resistance is not needed. As Valentine's Day is fast approaching, we wanted to showcase a fun way for beginners to make a unique DIY gift. The possibilities are endless, as you're only limited by your imagination and creativity!
Items to have:
Caprolactone Thermoplastic (You don’t need a lot)Latex glovesBoiling water with a bowl and spoon silicone ice cube tray or Jell-O tray of your desired designAcrylic paint, spray paint or Plasti Dip paint
Tips before you start:
1) Heating it too much will cause it to become too gooey, like pizza dough, making it difficult to get off your hands/gloves and insert into the molding.
2) You can use a soldering iron to curve and smooth out the edges a bit.
3) Having constant boiling water close at hand to re-melt the plastic if needed really helps the first test.
4) We used tap water and boiled it in a small electric kettle, then transferred the boiling water to a bowl and poured in the plastic beads to start the softening process. This technique didn't quite soften the plastic enough and while some beads were melted, others were still solid. We would highly recommend keeping your water at a constant boil while the plastic softens to get all of the beads to the same consistency of "meltiness".
Step 1: Molding Caprolactone Thermoplastics
Start by boiling some water and carefully pouring it into a bowl. Add some thermoplastic beads to the water and stir it around with a spoon. After a couple of seconds, you should see the pebbles change from their milky white color to transparent like in the picture below. While being careful not to burn yourself, scoop the plastic out of the water, knead it into a ball, and then fit it into your mold. If the result wasn't what you were hoping for, not to worry! Simply put it back into the bowl with some newly boiled water and reform it again!
Step 2: Moulding and Taking Out Theromoplastics
Carefully remove the thermoplastic from the mold, trying not to shift the shape of the plastic in the process. In our case, we wanted to try bending the flower pedals upwards so we removed it before it fully cooled. However, if you wish, you can leave it in the mold until it cools and hardens before removing it.
Step 3: Decorate Your Flowers
Get creative! We used some Plasti Dip paint which is rubberized and easy to peel off. You can use acrylic paint or other spray paint if you wish! There are dye powders out there, though they can be a bit pricey. Patience is key when spraying. Work in a well-ventilated area and use scrap cardboard underneath your plastic to prevent the paint from ruining your work surface. Hold the nozzle before contacting the plastic and move it side to side. It's okay to do multiple layers to get an even coat. You may need to rotate the cardboard to get at different angles of the flower.
Step 4: Final Touches on Spray and You're Done!
Check for any spots you may have missed in spraying. Once you're happy with the results, remove the flowers off the cardboard and check to see if any layers of spray haven't bonded to the cardboard. Once it's all dry you are good to go! This is our result of the Caprolactone Thermoplastic flowers!
PS: If you decide to DIY this project, drop us an email at media@solarbotics.com so we can feature your results!
    • Organization Contest
    • Warm and Fuzzy Contest
    • Sweet Treats Challenge
    2 Discussions
    Penolopy Bulnick
    8 days ago
    Neat! I've seen those plastics before but never thought to use them with a mold :)
    SolarboticsPenolopy Bulnick
    Reply 8 days ago
    Thanks, Penolopy! It was definitely fun to make and easy to remelt if there was any hiccups.
