Three French Hens in the Box (with Micro:bit)
Introduction: Three French Hens in the Box (with Micro:bit)
About: Get hacking in the most unconventional ways! Analog prototyping, digital tinkering, and everything in between. Get inspired to make, and share your making knowledge. 📲Follow us on Instagram @letsgethackin...
Surprise (or scare) people with three hens jumping out of a box. A holiday twist with electronics on the classic Jack-in-the-box. These three hens are French, of course.
Supplies:
  • 1 milk carton (1 Litre or Quart)
  • 3 toilet rolls3 ping pong balls
  • 3 sheets of A4/letter paper (stiffer is better)
  • 3 micro servo motors
  • adhesive tape
  • mounting tape
  • Blu Tack
  • micro:bitTinkercademy GVS Breakout Board for Micro:bit (or similar)
Teacher Notes
Step 1: Prepare the Box
Cut three lids (6 cm by 6cm or 2.36 inches) with a spacing of 1cm or 0.4 inches in between for the hens to pop out from. Remember to leave one end attached to the milk carton as that will serve as a lid. Cut the other end about 1cm or 0.4 inches from the opposite edge so you have a mini-lid for servo motors.
Step 2: Adding Servo Motors
Use mounting tape to attach a servo motor to each lid. Position the rotor such that it can form a latch for each of the lids. Run the servo wires out through the spout – this is easier if you're using a carton with a screw top.
Step 3: More Prep Work
Mark the required length of each toilet roll. We want them to be just a little shorter than the height of the carton (when on its side, of course). You can hold a sharpie stationary on one corner of the box and rotate the toilet roll against the sharpie to get a nice marking line.
Step 4: Cardboard Flange
Cut slits to the line we marked then flatten and trim to about 1 cm or 0.4 inches all around. Here we're making a little cardboard flange as a base for the french hens.
Step 5: Access Panel
Cut an access panel along the back of the carton. This will make it easier to reach in and attach toilet rolls to the inside of the carton.
Step 6: Adding the Base
Centre each toilet roll within each lid and tape the bottoms to the inside of the carton. The toilet rolls help ensure each Hen-in-the-box goes straight up and does not get stuck in some other part of the milk carton. Also, tape the top of each cardboard roll to the side of each pocket to keep the toilet rolls centred.
Step 7: Making Paper Springs
Begin with 2 strips of paper of equal sizes, such as 8.5 inch by 1 inch or 21 cm by 2.5 cm. Tape one end of these strips together, overlapping the ends so that the strips form a right angle.
Snugly fold the lower paper strip over the top one. Next, fold the paper strip that is now the lower later snugly over the paper which is now on top. Continue this process of always folding the lower strip over the top strip, until the entire length of the paper has been folded into a neat little square.
We used 3 pairs (6 strips) for each hen.
Step 8: The Hens
Draw a chicken face on each ping pong ball. It helps if you have red, yellow, and black markers. Cut out a comb from red paper and tape it to the top. Finally, attach the hen to each paper spring using Blu Tack.
Step 9: Hens Meet Box
Roll some clear tape onto itself to make it double-sided and attach it to the bottom of each paper spring. We don't use actual double-sided tape because the added height of the rolled tape makes it easier to attach. Slide each hen into a toilet roll and press down so the tape attaches at the bottom.
Step 10: Almost There
Close each lid and attach each servo motor to a micro:bit via a breakout board. Code it up to rotate each servo one by one (press reset to move the servos into a locked position, press the A button to open). Enjoy!
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    3 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    11 days ago
    This looks like such a fun project! Do you have a video of it?
    Lets Get Hacking
    Lets Get Hacking
    Reply 10 days ago
    Thank you! Yes, thank you for asking! I've added a GIF, in the intro section.
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 10 days ago
    Thanks for the gif! It's fun to see it in action :)
