Three Push ON – Push OFF Latching Circuits
Introduction: Three Push ON – Push OFF Latching Circuits
A flip-flop or latch is a circuit that has two stable states and can be used to store state information. The circuit can be made to change state by applying a signal (in this case, by pushing a button).
Here, I will show you three different ways to make latching circuits:
  1. Using 555 Timer IC
  2. Using Transistors
  3. Two Switches
I will also show you how to toggle between two outputs (by using transistors), using a single push button switch.
Pushing the push button once turns ON the output (LED), and pushing it again turns it OFF.
You can also use separate Push Buttons to switch ON and OFF the load.
Teacher Notes
Step 1: Circuit Diagram
These are the circuit diagrams for:
  • 555 Timer IC
  • Toggle Switch
  • Transistors
  • Two Switches
Step 2: Components
These are the Components Required for:
• 555 Timer IC
• Push Button Switch
Resistors: 100K, 10K (2), 330Ω
Capacitor: 1 μF
• LED
Transistors: BC547 (2), BC557
Resistors: 1M, 470K, 220K (2), 100K (2), 10K, 1K, 330 Ω
Capacitor: 1 μF
• LED
3. Using Two Switches
Transistors: BC547, BC557
• Push Button Switches (2)
Resistors: 10K, 1K (3), 330 Ω
• LED
Other Requirements:
• Battery: 9V and battery clip
• Breadboard
• Breadboard Connectors
Step 3: Step-by-step Tutorial
This video shows you step-by-step, how to build all these circuits.
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    2 Discussions
    ganeshk86
    ganeshk86
    Question 5 months ago on Step 2
    i'm tried latch circuit using 555 but not getting proper output..... even checked all the connections and component also.
    Interesting. I hadn't seen latching circuits using just transistors before. Thanks for sharing.
