Three Touch Sensor Circuits + Touch Timer Circuit
Introduction: Three Touch Sensor Circuits + Touch Timer Circuit
Touch Sensor is a circuit which turns ON when it detects the touch on the Touch Pins. It works on transient basis i.e. the load will be ON only for the time the touch is made on the pins.
Here, I will show you three different ways to make a touch sensor circuit :
1. Using Single Transistor
2. Using Two Transistors
3. Using 555 Timer IC
You can also make a Touch Timer Circuit (on adding a capacitor to 555 Timer IC circuit) which will allow the output to remain ON for some desired moment of time before turning it OFF.
Step 1: Components Required
These are the Components required for making the circuit:
  • Touch Pins (2)
  • Transistors: BC 547
  • Resistors: 330 Ω
  • LED
  • Touch Pins (2)
  • Transistors: BC 547 (2)
  • Resistors: 330 Ω
  • LED
  • 555 Timer IC
  • Touch Pins (2)
  • Resistors: 330 Ω, 10K Ω
  • LED
Other Requirements :
  • Battery: 9V and battery clip
  • Breadboard
  • Breadboard Connectors
Step 2: Circuit Diagrams
These are the Circuit Diagrams for:
  • Single Transistor
  • Two Transistors
  • 555 Timer IC
  • Touch Timer Circuit
Step 3: Controlling Touch Timer Circuit
You can refer these values to control the time for which the output will remain ON in Touch Timer Circuit.
Step 4: Step-by-step Tutorial
This video shows step-by-step, how to build all these circuits.
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
