Three Ways to Make LED Chaser Circuit With Speed Control + Back and Forth Effect
Introduction: Three Ways to Make LED Chaser Circuit With Speed Control + Back and Forth Effect
LED Chaser Circuit is a circuit in which the LEDs lights one by one for a period of time and the cycle repeats giving the running light appearance.
Here, I will show you three different ways to make a LED Chaser Circuit :-
1. 4017 IC
2. 555 Timer IC
3. Only Transistors
You can also control the speed of all the three circuits by varying the resistance.
Teacher Notes
Step 1: Components Required
These are the Components Required for making the circuit:
1. Using 4017 IC ()
• 4017 IC
• 555 Timer IC
• Potentiometer (10K Ω)
• Resistor: 1 K Ω
• Capacitor: 10 μF
• LEDs (10)
2. Using 555 Timer IC ()
• 555 Timer IC
• Zener Diode 1N4148
• Transistors: BC 547 (4)
• Resistors: 47K, 10K, 1K (2), 330Ω (4)
• Capacitors: 10 μF, 470 μF
• LEDS (4)
3. Using Only Transistors ()
• Transistors: BC 547 (3)
• Resistors: 100K (3), 2.2K (3)
• Capacitor: 10 μF (3)
• LEDs (3)
Other Requirements :
• Battery: 9V and battery clip
• Breadboard
• Breadboard Connectors
Step 2: Circuit Diagrams
These are the Circuit Diagrams for making the circuit using:
  • 4017 IC
  • 555 Timer IC
  • Only Transistors
Step 3: Step-by-step Tutorial
This video shows step-by-step, how to build all these circuits.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
