Through the City
Everyone has different ideas and ideas. The creative creation of skateboard exactly reflects the creation and imagination of one's heart. Every skateboard has a story, unique original intention and dream.This skateboard is not only a creation, but also represents my love and passion for invention.
Teacher Notes
Step 1: Step 1: Wheels
In TINKERCAD, the first idea was to build a
cylinder to stretch and shrink to reach its purpose -- the wheel. However, in TINKERCAD, I found some interesting parts, wheels and tires.Note (tire height: 5mm, diameter: 7mm. Wheel: height: 5mm, diameter: 10mm)
Step 2: Step 2: Bearing
Bearing, it is an indispensable part of
wheels, but the construction is very difficult, to build a first column, and then build a another smaller than the original cylindrical column, then the small cylinder into the hollow, after alignment group, become a part, is not easy to do the most part, however, after calculation, calculate the ball diameter and cylinder can accommodate the number of the last copy and paste, mobile has become a bearing.Note (ball radius: 0.5mm cylinder radius 0.7, height 2.8mm)
Step 3: Step 3: Bearing End Cover
This is done directly by using a sphere in
TINKERCAD that has been scaled up.Note (height: 1mm diameter 2mm)
The first large part of the wheel was completed successfully
Step 4: Step 4: Axis
The
shaft is formed by a cylinder after stretching and shrinking.Note (diameter: 2mm height: 27mm
Step 5: Step 5: Connectors
The shaft is formed by a cylinder after stretching and shrinking.Note (diameter: 2mm height: 27mm)
The cylinder (hollow mark)is used for steering.
And then you need to fix it
The cone has a fixed function note (diameter:
1.5mm, height: 1.5mm)
Step 6: Step 6: Long Board
The
long plate consists of two parts, a rectangle and a paraboloid.
First, the
cuboid is composed of a paraboloid, and then the paraboloid is tilted upward by 5 degrees. Finally, copy and paste the paraboloid and a long plate is completed.Cuboid, note (length: 64mm; width: 30; height: 1mm)
Step 7: Step 7: Decorate
A bare
skateboard is boring.
Take advantage of the ability to edit text and pictures in TINKERCAD
And then move that onto the long board
Finally finished skateboard!
Step 8: Step 8: Finish the Skateboard
Skateboard Contest
Skateboard Contest
1 Person Made This Project!
  • Make it Glow Contest
  • STEM Contest
    STEM Contest
  • Furniture Contest
    Furniture Contest
