Time Attendance System With RFID Using Arduino, SD Card Module and Real Time Clock
About: Share Knowledge about Arduino, ESP,GSM,Basic Electronics, DIY PROJECTS, Raspberry pi
Attendance has been an indispensable part since the times when professional lives came into existence whether be it schools, offices, colleges and other work places. Attendance marked up as an important record of the people who are at work and also the time according to which the people should be present at work.
This blog is all about building a time attendance system with RFID reader and Arduino. When we swipe an RFID tag next to the RFID reader, it saves the user-id and timing in SD card and it also shows if you are late or according to time and if late then how much late.
The RFID stands for Radio Frequency Identification. The RFID uses electromagnetic field to transmit data over short distances. It is also usefull identify people and make transactions and much more.
Components Required -:
Teacher Notes
Step 1: Making Connections/Schematics
Make connections according to the given schematics. Download schematics
MFRC522 RFID reader pinout
Pin Wiring to ARDUINO UNO
SDA == Digital 10
SCK == Digital 13
MOSI == Digital 11
MISO == Digital 12
IRQ == Don't Connect
GND == GND
RST == Digital 9
3.3V == 3.3 V
RTC module pinout
PIN == Wiring to Arduino Uno
SCL == A5
SDA == A4
VCC == 5V
GND == GND
SD card module pinout
Pin Wiring to Arduino Uno
VCC == 3.3V
CS == Digital 4
MOSI == Digital 11
CLK == Digital 13
MISO == Digital 12
GND == GND
Step 2: Preparing the SD Card
Preparing the SD Card will have the following steps -:
  • Formatting the SD Card as F8032 or F8016
For formatting the SD Card, insert it in your computer and go to "this PC" > right click on the SD Card option and select formatt. A dialogue box will pop-up, Select F8032 from it and press start to initialize the process.
Step 3: Checking and Uploading Code
The code starts from importing the libraries MFRC5224 and RFID reader, SD fro the SD Card module and an RTC lib for the RTC module. Here we also include SPI library for SPI communication with RFID in SD Card module.
  • pins are defined for RFID and SD Card module
  • A file named "My file" is created to store our data.
  • Create an instance for the RFID and the RTC.
  • After this we create a string variable that contains the UID tag.
  • Certain variables are defined to hold the check-in time, hour and minute.
  • We also need to introduce variables to hold the user check-in hour.
  • Now upload code to your Arduino board.
Click here for the code
Step 4: Open Serial Monitor and Check Working
The correct timings to arrive and leave are entered into the code and system or module works automatically.
  • If you are late according to the time set in the code then a red led glow and serial monitor would display "You are late".
  • If you are on time according to the time set in the code then a green led will glow and serial monitor will display " You're Welcome".
  • Here UID's can also be checked and user name can also be displayed.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
