Introduction: Timelapse Slider With VB
The aim of this first integration test with visual basic is to understand the basics. So, we are just going to make a small test application to control one motor and the camera shutter. You can download all project files and sketches here: http://timeblocks.wordpress.com/
Step 1: Download Visual Basic 2010 Express
Let´s start by downloading Visual Basic Express here.
Step 2: Open Visual Basic
Follow the steps until you successfully install VB and then open it:
Step 3: New Project.
Click new project, then click Windows Forms Application followed by ok:
Step 4: Buttons
Drag four buttons from the toolbox into form1:
Step 5: Serial Port
Drag SerialPort element from toolbox into form1 :
Step 6: VB Code
Copy the following code:
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
Shared _continue As Boolean
Shared _serialPort As SerialPort
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SerialPort1.Close()
SerialPort1.PortName = “com3″ ‘change com port to match your Arduino port IMPORTANT
SerialPort1.BaudRate = 9600
SerialPort1.DataBits = 8
SerialPort1.Parity = Parity.None
SerialPort1.StopBits = StopBits.One
SerialPort1.Handshake = Handshake.None
SerialPort1.Encoding = System.Text.Encoding.Default
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click, Button1.Click
SerialPort1.Open()
SerialPort1.Write(“1″)
SerialPort1.Close()
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
SerialPort1.Open()
SerialPort1.Write(“0″)
SerialPort1.Close()
End Sub
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
SerialPort1.Open()
SerialPort1.Write(“3″)
SerialPort1.Close()
End Sub
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
SerialPort1.Open()
SerialPort1.Write(“4″)
SerialPort1.Close()
End Sub
End Class
Step 7: Arduino Sketch
Upload the following code to the arduino board:
# define PIN_M1_DIRECTION_FW 7 // m1 forward
# define PIN_M1_DIRECTION_RV 8 // m1 reverse
# define PIN_M1_SPEED 5 // m1 speed
# define PIN_FOCUS 6 // focus
# define PIN_SHUTTER 9 // shutter
void setup() {
Serial.begin(9600);
pinMode(PIN_M1_DIRECTION_FW, OUTPUT);
pinMode(PIN_M1_DIRECTION_RV, OUTPUT);
pinMode(PIN_M1_SPEED, OUTPUT);
pinMode(PIN_FOCUS, OUTPUT);
pinMode(PIN_SHUTTER, OUTPUT);
void loop(){
while (Serial.available() == 0);
int val = Serial.read() – ‘0’;
f (val == 1) {
analogWrite(PIN_M1_SPEED, 255);
digitalWrite(PIN_M1_DIRECTION_FW, HIGH);
digitalWrite(PIN_M1_DIRECTION_RV, LOW);
else if (val == 0){
analogWrite(PIN_M1_SPEED, 0);
digitalWrite(PIN_M1_DIRECTION_FW, LOW);
else if (val == 3) {
digitalWrite(PIN_M1_DIRECTION_RV, HIGH);
else if (val == 4) {
digitalWrite(PIN_FOCUS, HIGH);
delay(100);
digitalWrite(PIN_SHUTTER, HIGH);
delay(100);
digitalWrite(PIN_FOCUS, LOW);
digitalWrite(PIN_SHUTTER, LOW);
delay(100);
else
Serial.println(val);
Serial.flush();
Step 8: Testing
Connect the camera and motor to tb.shield, push play in vb and test it.Now its time to play. Enjoy it.
