Timer for Light Fixture [Temporizador De Apagado De Lampara]
Introduction: Timer for Light Fixture [Temporizador De Apagado De Lampara]
About: I love to do electronics projects, and also to share them
It has been a long time since I have post my last instructable, so I decided to post another of my electronic proyects.
I have a light fixture of two types of lighting mode, one for study that are two T5 fluorescent tubes of 28 watts that are cold white light (6000 k) and the other for reading with one T8 fluorescent tube of 17 watts that is warm white light (4100 k), sometimes I just enter to the room for some items so I left the lights turned On and there is a waste of energy, the solution is simple, by adding an electronic timer I can just enter to the room, push the start button of the timer and the light should turn off in 3 minutes in its own.
Ha pasado mucho tiempo desde que publique mi ultimo instructable, asi que decidi publicar otro de mis proyectos electronicos
Tengo una lampara que tiene dos tipos de iluminacion, uno para estudiar que esta compuesto por 2 tubos fluorescentes T5 de 28 watts con luz fria (6000 k) y otro para leer con una potencia de 17 watts T8 y luz calida (4100 k), a veces entro a la habitacion para tomar algunas cosas y dejo la lampara encendida, por lo que hay un gasto de energia, la solucion es simple, al agregar un temporizador electronico puedo entrar en la habitacion, presionar el boton de inicio del temporizador y la luz deberia apagarse en 3 minutos por si sola.
Step 1: Materials and Tools [Materiales Y Herramientas]
For the materials we will need
-The xy-j02 timer module
-Two or more meters of 18 gauge wire (Depending on the location of the lamp the meters of wire)
-One meter of 22 gauge wire for the led and momentary switch
-Green led with his own clip to install to the light fixture
-Momentary switch
-M4 Screws and nuts
-Zip ties
Tools
-Drill with a small drilling bit which allow the screws pass
-Isolate tape
-Cutting Pliers
-Soldering Iron with some soldering
-Screwdrivers
Para los materiales vamos a necesitar
-El modulo timer xy-j02
-Dos o mas metros de cable calibre 18 (Depende de la ubicacion de la lampara el numero de metros de cable)
-Un metro de cable calibre 22 para la conexion del led y el interruptor momentario
-Un led verde con su portaled
-Un interruptor momentario
-Tornillos y tuercas M4
-Sujetadores plasticos
Herramientas
-Taladro con una broca pequeña que permita pasar los tornillos
-Cinta de aislar
-Pinzas de corte
- Cautin con un poco de soldadura
-Destornilladores
Step 2: Install the Module and Make the Wiring [ Instalar El Modulo Y Hacer Conexiones]
Before starting to work is important to make sure you have the mains switch in the off position, otherwise you can get shocked, also before touching a wire use a tester to probe if there is any present voltage.
Once we are safe we can unscrew the wires and light fixture from its place, find out a good place for the controller and power supply, in my case the light fixture is made of metal so I added some isolating tape to prevent short circuit from the controller or power supply pcb, also I added a jumper to allow the external start switch, the holes to solder are next to the power screw terminals.
Mark some mounting holes in the light fixture and make them with the drill being careful from damaging the paint of the light fixture.
Install the module with the screws and nuts, then make the wiring according to the schematic, since I have installed the light fixture I added a 1 amp fuse before the light switch, so I recommend to install one in series with the light switch of the lamp to be more safe, its important to know the ratting of the fuse that is needed, for that check the information of the ballast to know the current consumption, in my case its 0.6 amps, so I added a 1 amp fuse.
Is important to double check the wiring to know if there arent any short or mistake, with a multimeter in continuity mode test if there is a short between the mains Ac wires. Once you are sure, turn on the mains switch .
Antes de iniciar a trabajar es importante que estes seguro que el interruptor principal de la casa esta en la posicion de apagado, de lo contrario puedes recibir una descarga electrica, tambien antes de tocar un cable, usa un probador para saber si no existe voltaje presente.
Una vez que estamos seguros podemos desatornillar los cables y la lampara de su lugar, encuentra un buen lugar para el controlador y fuente de poder, en mi caso la lampara es de metal asi que agregue un poco de cinta de aislar las terminales pcb de la fuente de poder o modulo, tambien agregue un jumper para permitir el boton externo de inicio, el sitio para instalarlo esta a un lado de la terminal de tornillos de alimentacion.
Marca los lugares de perforacion en la lampara y realizalos con el taladro teniendo mucho cuidado de no dañar la pintura de la lampara
Instala el modulo con los tornillos y tuercas, despues realiza el cableado de acuerdo al esquema, desde que instale la lampara le agregue un fusible de 1 amperio antes del interruptor de la lampara, asi que recomiendo instalar uno en serie con el interruptor de la lampara para estar mas seguros, es importante saber el amperaje del fusible necesario, para eso revisa las especificaciones de la balastra de la lampara para saber el consumo de corriente (amperes), en mi caso son 0.6 amperios, asi que agregue un fusible de 1 ampere.
Es importante revisar dos veces el cableado para saber si no hay algun corto circuito o error, con un multimetro en el modo de continuidad prueba si no hay continuidad entre los cables principales de corriente alterna. Una vez que estes seguro, enciende el interruptor principal de la casa.
Step 3: Set Up the Module and Test [Programar El Modulo Y Probar]
The last step of this instructable is to program the module, for that we need to press the SET button for 2 seconds, after that the mode will appear, I select the P 1.3, but you can choose other modes that are useful for you, the information about how to program is in the product details from this website https://www.aliexpress.com/item/integrated-circuit... , I tried to find out a PDF datasheet , then push again SET and OP will appear, then a number, you can set seconds or minutes with the STOP button and change the value with UP and DOWN buttons, again press SET and the programming is ready, just push the start button and the time should start running, the indicator led also turns on , turn down the light switch . After the programmed time the light should turn off.
I expect you liked the proyect, If you have questions please share them in the comments, Thanks for your attention
El ultimo paso de este instructable es programar el modulo, para eso necesitamos presionar SET por 2 segundos, despues el modo va aparecer, yo elegi el modo P 1.3, pero puedes elegir otros modos que sean utiles para ti, la informacion acerca de como programar esta en los detalles del producto de este sitio web https://www.aliexpress.com/item/integrated-circuit... intente buscar un PDF en español, pero no encontre ,despues presione de nuevo SET y OP deberia aparecer, despues un numero, puedes elegir segundos o minutos con el boton STOP y cambiar el valor con los botones UP y DOWN, despues presione SET y la programacion esta lista, solo presione el boton de inicio y el tiempo empezara a correr,el led indicador encendera, apague el interruptor de la lampara . Despues del tiempo programado la lampara deberia apagarse.
Espero te haya gustado el proyecto, Si tienes preguntas por favor compartelas en los comentarios, gracias por tu atencion .
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
