Tiny Wooden House on a Rock
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
In this instructables I am going to share how to make miniature wooden house. It is tiny and super fun to make. needs a patients and time.... Main items used in this instructables was found easily. I did not buy anything....
I worked on this project every night after dinner for 2 to 3 hrs ( last 1 week ).. I certainly learnt a lot
Teacher Notes
Step 1: What Do You Need ?
Material
  • A rock or stone : I found mine on road
  • Popsicle sticks : Mine were thinner than regular fund them at the coffee station
  • PVA glue or fevicol
  • Cutter
  • Tooth picks
  • Skewers
  • Acrylic paints etc
  • Dried bamboo twigs from my apartment garden
No power tools needed, just you imagination
Step 2: Prepare
  • Wash the rock, bamboo twigs and let them to dry
  • Glue several popsicle stick to make few thin wooden planks / sheets
  • Let the glue dry before we start the next step
  • Add supports as needed
Step 3: House
  • Cut the wood sheets as shown above
  • Glue them together
  • I used paper tape to hold them together and added a support inside to prevent it collapsing
  • Let it dry for 2 hours
  • Add details like doors, chimney and base etc
Tips :
  • You could choose a different shape for your house
  • To simplify this step, you could take a big piece of wood and shape it into a house using saw and then sticking popsicle picks for details
Step 4: Path on the Rock
  • The idea is that this rock is a hill or a island in water
  • We have a wooden path which goes around the rock
  • This path has is has moss etc
  • I started at the top and slowly added each piece
  • Added support where the popsicle stick was touching the rock
  • After every piece, you need to wait for 2hrs to dry
  • Once done paint the patch with watery green and brown
Tips :
  • If you are comfortable using super glue, this step gets done faster
  • I always end up gluing myself and making change later is difficult
  • While one piece was drying I would work on another, like painting or tree etc
Step 5: Boat
  • Take 4 to 5 pieces of popsicle sticks between 3 to 4 cm
  • Glue them together and leave them to dry
  • Once dried, use a sandpaper and cutter to give this a boat like shape
  • Leave the boa's bottom flat, so that it could stand upright without an additional support
  • Add the central mast and two sails
  • Glue them and let it to dry
Step 6: Paint Job
  • Using Acrylic paints ( I you may choose different colors)
    • Paint brown ( water wash ) to give the wooden finish
    • Paint green, let it dry
    • Now paint teal Blue, leaving some of the green to still be visible like moss
  • For the roof, i rubbed a little black paint
  • I accidentally painted the sails, so had to retouch them with whit paint
  • You could try different color scheme
  • While my looked amazing with a white background, on a darker shelve I will have to change the colors
Step 7: Detailing
  • Before we start detailing, we need to glue the house and level it
  • I added dummy supports for the house at the back and front
  • Added tress ( bamboo twigs)
  • Added few more branches by gluing more twigs
Tips :
  • Using Super glue could definitely speed up the process
  • Take a pause after every step... rest a bit and then continue
Once everything is dried, place the new tiny wooden house to display on the showcase or find a spot
Future Improvements
  • Add led lights, why ? Because I love them and will be more visible on a darker shelf
  • Add more details to Tree, fence to path and a swing
Please share your suggestion, comments and how can I improve further
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
