Toilet Flange Repair
Discovered broken flange while repairing leaking toilet. Step by step process to repair broken toilet flange.
Supplies:
5/8 wrench
7/16 wrench
Hammer Drill
Concrete drill bit and screws
Wax ring
Towels
Putty knife
Teacher Notes
Step 1: Step 1- Assemble Supplies
Step 2: Step 2: Turn Off Water Supply
Place towel on floor to catch water.
Step 3: Step 3: Disconnet Water Supply Line
Use 5/8 inch wrench
Flush toilet to remove excess water
Step 4: Step 4: Dip Water From Tank
Step 5: Step 5: Lift Toilet Off Flange
Step 6: Step 6: Remove Old Wax From Flange
Use putty knife to remove wax
Step 7: Step 7: Inspect Damaged Flange
Step 8: Step 8: Drill Holes Into Concrete Floor
Use hammer drill, concrete bit and screws
Step 9: Step 9: Place Repair Flange on Exisiting Flange
Secure with concrete screws
Step 10: Step 10: Place New Seal/ Wax Ring Onto Flange
Step 11: Step 11: Replace Toilet
Secure with toilet anchor bolts.
Hand tighten bolts only to prevent cracking toilet.
Step 12: Step 12: Reattach Water Supply Line
Check for water leaks.
Toilet is now ready for use.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
