Touch ON - Touch OFF Circuit + Touch Toggle Circuit
This is a circuit which can be controlled by a Touch. Two input Touch pin pairs controls the circuit output – one pair turns the circuit ON, while the other turns it OFF.
The circuit can also be extended to toggle between two outputs, where the two touch pin pairs controls the two respective outputs.
Teacher Notes
Step 1: Components Required
These are the Components Required for making the Touch ON –Touch OFF circuit:
  • 555 Timer IC
  • Resistor: 330 Ω
  • LED
  • Touch Pins (4)
Other Requirements :
  • Battery: 9V and battery clip
  • Breadboard
  • Breadboard Connectors
Step 2: Circuit Diagram
These are the Circuit Diagrams for:
  • Touch ON – Touch OFF Circuit
  • Touch Toggle Circuit
Step 3: Step-by-Step Tutorial
This video shows step-by-step, how to build these two circuits.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
