Touch ON Touch OFF Switch | Latching Circuit | 555 Timer Projects
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make touch on touch off circuit using 555 timer
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/touch-on-touch-off-switch...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Hardware
❖ Hardware Required ❖
► 555 Timer IC
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► 10k ohm resistor
► 100k ohm resistor
► 1k ohm resistor
► 1uf capacitor
► LED
❖ Circuit Diagram ❖
Link ► https://www.file-upload.com/e10g1fjqwjjd
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect IC )
► Connect 555 timer IC on bread board
STEP # 2 ( Make connections )
► Pin 8 of 555 Timer – To VCC of Battery
► Pin 1 of 555 Timer - To GND of Battery
► Connect wire BTW Pin 2 and Pin 6
► Connect wire BTW Pin 4 and Pin 8
STEP # 3 ( Connect Resistor #1 )
► Connect 10k ohm resistor BTW Pin 6 and Pin 8
► Connect 10k ohm resistor BTW Pin 1 and Pin 6
STEP # 4 ( Connect Capacitor )
► Connect negative side of 1uf capacitor on Pin 1 and positive side on x row of breadboard
STEP # 5 ( Connect resistor #2 )
► Connect 100k ohm resistor BTW pin 3 and positive side of capacitor
STEP # 6 ( Connect resistor #3 and LED )
► Connect LED and 1kohm resistor on pin 3 and GND
STEP # 7 ( Conenct Push Button )
► Connect push button and connect positive side on pin 2
► Connect negative side of push button on pin 1
STEP # 8 ( TESTING )
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
