Touch on Touch Off Switch | Basic Electronics Projects | 555 Timer Projects
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make a simple touch On and touch off switch using 555 timer ic
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/touch-on-touch-off-switch...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 555 Timer IC
► 9V Battery with Clip
► Breadboard
► Jumper Wires
►270 ohm resistor
► metal wire x2
❖ Circuit Diagram ❖
Link ► https://www.file-up.org/b6682n06vo7v
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect IC )
► Connect 555 timer IC on bread board
STEP # 2 ( Make power connections )
► Pin 8 of 555 Timer – To VCC of Battery
► Pin 1 of 555 Timer - To GND of Battery
► Pin 6 of 555 Timer - To Pin 2 of 555 Timer
STEP # 3 ( Connect LED )
► Connect +v LED pin on pin 3 and -ve pin on X-rows of breadboard
STEP # 4 ( Connect Resistor )
► Connect 270 ohm resistor BTW pin 1 and -ve terminal of LED
STEP # 5 ( Connect metal wire/touch probes )
► connect two metal probes one on pin 8 and the other on pin 6
► connect two more on pin 1 and pin 2 STEP # 6 ( testing )
    • Epilog X Contest
      Epilog X Contest
    • Weaving Challenge
      Weaving Challenge
    • Remix Contest
      Remix Contest
